Traditional switches are not designed to be installed in a living room, bedroom, or office desk, so usually we hide them because the design is not user-friendly - they have flashing LED lights and a bunch of cables that we don't want to see. NETGEAR tackles this problem head-on with the industry's first consumer-friendly switch with integrated cable management. The 900 Series switches are the first switch that you want to display! Thanks to the stylish design and the built-in cable organizer, you will keep your office and home neat and tidy. Moreover the LED ON/OFF button will keep your environment quiet so no light will disturb your movie, work or sleep
                Integrated cable managementKeeps your office and home neat and tidy, with organized cables.
                USB charging portsConveniently placed to allow you to charge your smartphone and tablet.
                Silent and invisibleInnovative, fanless design with an on/off LED light button.
                Easy to use web interfaceIntuitive and simple, with rich and advanced functions.
- NETGEAR Plus GS908E - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 1000Base-T
- Performance
- Bandwidth: 16 Gbps , Packet forwarding rate: 11.9 Mfps , Latency (10 Mbps): < 76.9 µs , Latency (100 Mbps): < 9.1 µs , Latency (1000 Mbps): < 2.7 µs
- Capacity
- Multicast groups: 128 , Priority queues: critical/high/medium/low , VLANs supported: 64 , Maximum member ports per LAG: 4
- MAC Address Table Size
- 4K entries
- Jumbo Frame Support
- 9000 bytes
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- IGMP snooping, Quality of Service (QoS), Jumbo Frames support, fanless, on/off switches, DHCP client, Class of Service (CoS), power-saving mode, cable management, ingress rate limiting, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), VLAN Tagging, port-based VLAN, egress rate limiting, port-based QoS, port trunking, block unknown multicast, static multicast router port
- IEEE 802.1p, IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 23.4 cm x 16.4 cm x 3.3 cm
- 370 g
- Localisation
- New Zealand, United Kingdom
- 3-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 1000Base-T
- Performance
- Capacity
- 4K entries
- 9000 bytes
- Routing Protocol
- Status Indicators
- Power, link/activity/speed
- 8 x 1000Base-T RJ-45 , 2 x USB (power only)
- Power Device
- External power adapter
- Installed Qty
- 1
- Voltage Required
- Included Accessories
- Wall mounting kit, cable retention strap
- Plug and Play, UL 60950-1, EAC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, EN55022:2010 + AC:2011 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, EN 61000-3-2:2014 Class A, IEC60950-1:2005, Second edition + A1:2009 + A2:2013, ICES-003:2016 issue 6 Class B, EN 6100-3-3:2013, AS/NZS CISPR22:2009+A1:2010 Class B, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, IEEE 802.1Q, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- 23.4 cm
- 16.4 cm
- 3.3 cm
- 370 g
- Limited warranty - 3 years , Technical support - 90 days
- 0 °C
- 40 °C
- 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 95% (non-condensing)
