NETGEAR Switch - Managed - 8 x 1000Base-T
Quicklinx: D9Q3BTBS Mfr#: GS908E-100UKS
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
£43.65 ex VAT
£52.38 inc VAT
Traditional switches are not designed to be installed in a living room, bedroom, or office desk, so usually we hide them because the design is not user-friendly - they have flashing LED lights and a bunch of cables that we don't want to see. NETGEAR tackles this problem head-on with the industry's first consumer-friendly switch with integrated cable management. The 900 Series switches are the first switch that you want to display! Thanks to the stylish design and the built-in cable organizer, you will keep your office and home neat and tidy. Moreover the LED ON/OFF button will keep your environment quiet so no light will disturb your movie, work or sleep
  • Integrated cable management
    Keeps your office and home neat and tidy, with organized cables.
  • USB charging ports
    Conveniently placed to allow you to charge your smartphone and tablet.
  • Silent and invisible
    Innovative, fanless design with an on/off LED light button.
  • Easy to use web interface
    Intuitive and simple, with rich and advanced functions.
NETGEAR Plus GS908E - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 1000Base-T
Performance
Bandwidth: 16 Gbps , Packet forwarding rate: 11.9 Mfps , Latency (10 Mbps): < 76.9 µs , Latency (100 Mbps): < 9.1 µs , Latency (1000 Mbps): < 2.7 µs
Multicast groups: 128 , Priority queues: critical/high/medium/low , VLANs supported: 64 , Maximum member ports per LAG: 4
MAC Address Table Size
4K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
IGMP snooping, Quality of Service (QoS), Jumbo Frames support, fanless, on/off switches, DHCP client, Class of Service (CoS), power-saving mode, cable management, ingress rate limiting, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), VLAN Tagging, port-based VLAN, egress rate limiting, port-based QoS, port trunking, block unknown multicast, static multicast router port
IEEE 802.1p, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
23.4 cm x 16.4 cm x 3.3 cm
370 g
New Zealand, United Kingdom
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 1000Base-T
Performance
4K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Status Indicators
Power, link/activity/speed
8 x 1000Base-T RJ-45 , 2 x USB (power only)
External power adapter
Installed Qty
1
Wall mounting kit, cable retention strap
Plug and Play, UL 60950-1, EAC, CNS 13438, EN 55024:2010, FCC CFR47 Part 15 B Class B, EN55022:2010 + AC:2011 Class A, VCCI V-4/2012.04, VCCI V-3/2015.04 Class A, ANSI C63.4-2014, AS/NZS 60950-1:2015, EN 61000-3-2:2014 Class A, IEC60950-1:2005, Second edition + A1:2009 + A2:2013, ICES-003:2016 issue 6 Class B, EN 6100-3-3:2013, AS/NZS CISPR22:2009+A1:2010 Class B, IEC 60950-1:2005 (ed.2)+A1:2009+A2:2013, IEEE 802.1Q, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
23.4 cm
16.4 cm
3.3 cm
370 g
Limited warranty - 3 years , Technical support - 90 days
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 8
Managed: Yes
Brand: NETGEAR
