Transform your NETGEAR AirCard mobile hotspot into a powerful LTE router with this AirCard Smart Cradle. With high-gain internal 4G/3G antennas and external Wi-Fi antennas, 1 USB port and 5 Gigabit Ethernet ports, users can maximize the power of their mobile Wi-Fi network and get great performance needed for homes and offices.
Enhanced connectivity
With Ethernet 10Base-T/100Base-TX/1000Base-T interfaces and Wi-Fi 5 support, this device ensures high-speed connections across both wired and wireless networks. Its dual-band Wi-Fi capabilities allow for a more reliable and less congested network experience. -
Versatile connections
Featuring four LAN ports, one WAN port, two antenna connectors, a USB 3.0 port, and a Netgear Dock connector, the Smart Cradle offers a wide range of connectivity options to suit various networking needs. -
Advanced networking features
Equipped with Beamforming+ for improved Wi-Fi range and performance, ReadySHARE for easy sharing of a USB storage device, and Wi-Fi Protected Setup (WPS) for secure network access with the push of a button.
- NETGEAR AirCard Smart Cradle - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- WPS, ReadySHARE, reset button, Beamforming+
- DLNA CERTIFIED
- Power
- DC 12 V
- Localisation
- Europe
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- DLNA CERTIFIED
- Status Indicators
- Power, WAN, LAN, wireless, USB
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 2 x TS-9 , USB 3.0: 1 x 9 pin USB Type A , Mobile hotspot: 1 x Netgear Dock connector
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Voltage Required
- DC 12 V
- Localisation
- Europe
- Limited warranty - 1 year
