NetGear S3300 52-Port Stackable Smart Switch W/10G
Quicklinx: B2F7WS00 Mfr#: GS752TX-100NES
The ProSAFE S3300 52PT Gigabit Stackable Smart Switch is a L2+ web based platform: non-PoE in a 48 port configuration. 4 dedicated 10G ports are included as standard (2 x 10GBase-T and 2 x SFP+) for stacking and/or uplinks to aggregation layers or storage and server connections.
  • Enhanced connectivity
    With 48 10/100/1000 RJ-45 ports alongside 2 10GBase-T and 2 10Gb Ethernet SFP+ ports, this NETGEAR Smart S3300-52X switch offers a wide range of connection options for diverse networking needs, ensuring high-speed and reliable connectivity for all connected devices.
  • Robust security features
    Equipped with Access Control List (ACL) support, DHCP snooping, Dynamic ARP Inspection (DAI), and IP source guard, the NETGEAR Smart S3300-52X provides comprehensive security measures to protect against unauthorized access and network threats, maintaining a secure networking environment.
  • Optimized network performance
    Features such as Quality of Service (QoS), Weighted Round Robin (WRR) queuing, and bandwidth capacity of 176 Gbps ensure efficient traffic prioritization and management, delivering optimized network performance and enhancing the overall user experience.
  • Advanced management capabilities
    Manageable via CLI, HTTP, HTTPS, SNMP, and RMON, the NETGEAR Smart S3300-52X offers versatile management options for network administrators, enabling easy setup, monitoring, and maintenance of the network infrastructure.
  • Durable and reliable
    With a Mean Time Between Failures (MTBF) of 279,970 hours and a rack-mountable form factor, this switch is designed for longevity and easy integration into existing network racks, providing a reliable networking solution for businesses of all sizes.
NETGEAR Smart S3300-52X - switch - 52 ports - smart - rack-mountable
Switch - 52 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
Performance
Bandwidth: 176 Gbps
VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, WRED, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, DHCP client, Energy Efficient Ethernet, dual firmware images, SPQ, CoS, IP source guard
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
AC 100/230 V (50/60 Hz)
44 cm x 25.7 cm x 4.3 cm
3.66 kg
Latin America, North America, Europe
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 176 Gbps
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
6
Routing Protocol
Static IPv4 routing
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
128 MB
48 x 1000Base-T RJ-45 , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
Internal power supply
44.12 watt
Rack Mounting Kit
Included
MTBF
279,970 hours
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
44 cm
25.7 cm
4.3 cm
3.66 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
B2F7 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
