NetGear S3300 52-port Stackable POE Smart Switch W/10G
Quicklinx: B2F8WS00 Mfr#: GS752TXP-100NES
Type: Gigabit Ethernet
Ports: 52
Data Transfer Rate: 10Gbps
Managed: Yes
POE: PoE+
£1,145.16 ex VAT
£1,374.19 inc VAT
The ProSAFE S3300 52PT Gigabit Stackable Smart Switch is a L2+ web based platform : PoE+ in a 48 port configuration. 4 dedicated 10G ports are included as standard (2 x 10GBase-T and 2 x SFP+) for stacking and/or uplinks to aggregation layers or storage and server connections. PoE/PoE+ support between 190W up to 1,440W with RPS (model dependent).
  • Robust security
    With support for RADIUS and TACACS+ authentication methods, alongside a comprehensive Access Control List (ACL), the NETGEAR Smart S3300-52X-PoE+ ensures secure network access and precise control over user permissions.
  • High capacity and performance
    Designed to accommodate high traffic, this switch boasts a bandwidth of 176 Gbps, a MAC Address Table Size of 16K entries, and supports up to 256 VLANs, making it suitable for growing businesses.
  • Efficient power management
    Featuring PoE+ with a total budget of 390 W and ENERGY STAR Ethernet, the switch optimizes power usage, reducing operational costs while powering devices such as VoIP phones, IP cameras, and wireless access points.
  • Advanced networking features
    This switch supports a range of advanced features including Quality of Service (QoS) for traffic prioritization, IPv6 support, and static routing, enhancing network efficiency and preparing your infrastructure for the future.
  • Reliable and manageable
    With a mean time between failures (MTBF) of 216,809 hours, stackability up to 6 units, and comprehensive remote management protocols, the NETGEAR Smart S3300-52X-PoE+ is built for reliability and ease of management.
NETGEAR Smart S3300-52X-PoE+ - switch - 52 ports - smart - rack-mountable
Switch - 52 ports - smart - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
390 W
Performance
Bandwidth: 176 Gbps
VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, WRED, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, DHCP client, Energy Efficient Ethernet, dual firmware images, SPQ, CoS, IP source guard
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
AC 100/230 V (50/60 Hz)
44 cm x 34.5 cm x 4.3 cm
5.54 kg
Latin America, North America, Europe
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
390 W
Performance
Bandwidth: 176 Gbps
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
6
Routing Protocol
Static IPv4 routing
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
128 MB
48 x 1000Base-T RJ-45 PoE+ , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
Internal power supply
1484.12 watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
MTBF
216,809 hours
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
44 cm
34.5 cm
4.3 cm
5.54 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
B2F8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.52
Ports: 52
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: £1000 - £1500
