The ProSAFE S3300 Switch series is a new generation of Gigabit Stackable Smart Switches, inclusive of 4 dedicated 10G ports for uplinks and/or stacking between other S3300 switches. As SMBs produce and consume more data, Gigabit to the desktop increasingly needs to be underpinned with 10GbE connectivity to the core to ensure a consistent, seamless user experience. This new generation of switches provides SMB customers with the most cost-effective 10G connections between their Gigabit access layer switches and aggregation layer 10G switches and Routers. The ProSAFE S3300 Smart Series is the blueprint for a dependable future-proof network. From Greenfield network requirements to network refresh projects, the series sets new standards in defining flexibility and choice for SMBs looking to leverage reliable, future proof technologies at affordable price points.
Robust security
With support for RADIUS and TACACS+ authentication methods, alongside a comprehensive Access Control List (ACL), the NETGEAR Smart S3300-28X-PoE+ ensures secure network access and enhanced network control. -
Efficient performance
Featuring a bandwidth capacity of 128 Gbps and equipped with 24 PoE+ ports, this switch is designed to handle high-volume network traffic, ensuring efficient data flow across the network. -
Advanced networking
Supports a wide range of IEEE standards including 802.1Q VLANs, 802.1p Class of Service (CoS), and 802.3ad (LACP) for comprehensive network configuration and optimization. -
Energy efficient
Incorporates ENERGY STAR Ethernet (IEEE 802.3az) for reduced power consumption without sacrificing performance, making it an eco-friendly choice for your networking needs. -
Easy management
Manageable via CLI, HTTP, HTTPS, SNMP, and RMON, offering versatile management options to suit a variety of user preferences and ensuring easy setup and long-term maintainability.
- NETGEAR Smart S3300-28X-PoE+ - switch - 28 ports - smart - rack-mountable
- Switch - 28 ports - smart - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 195 W
- Performance
- Bandwidth: 128 Gbps
- Capacity
- VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
- Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, WRED, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, DHCP client, Energy Efficient Ethernet, dual firmware images, SPQ, CoS, IP source guard
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
- Power
- AC 100/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.3 cm
- 3.77 kg
- Localisation
- Latin America, North America, Europe
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 195 W
- Performance
- Capacity
- 16K entries
- 9KB
- Max Units In A Stack
- 6
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 800 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- 24 x 1000Base-T RJ-45 PoE+ , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- 748.18 Watt
- Rack Mounting Kit
- Included
- MTBF
- 147,965 hours
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
- Localisation
- 44 cm
- 25.7 cm
- 4.3 cm
- 3.77 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
