NetGear ReadyNAS NVX Pioneer Edition
Quicklinx: 6CSLWS00 Mfr#: RNDX400E-100EUS
The NVX Pioneer Edition is the next generation 4-bay ReadyNAS network attached storage model for advanced home users and media enthusiasts. Placed in the center of your digital home, it will revolutionize your home network both today and tomorrow! Advanced features, high storage capacity and class-leading performance let you store, share and protect files and digital media like never before.
  • Class-leading performance
    Powered by an Intel advanced embedded processor and the RAIDiator operating system, the ReadyNAS NVX Pioneer Edition offers the most sophisticated network storage for advanced homes with class-leading performance. Its 75+ megabytes per second read and write throughputs allow you easily backup multiple computers, transfer large files and stream multimedia data all at the same time.
  • Advanced energy-saving design
    The compact design of the ReadyNAS NVX Pioneer Edition is just slightly larger than the 4 drives stacked. Smart energy-saving modes like disk spin-down, a scheduled power timer, and Wakeon-LAN allow standby or power-off modes when not in use, lowering power bills, extending system life and consuming fewer resources. And, with strategically placed fans, the ReadyNAS NVX Pioneer runs quietly enough to live in any home, yet keeps your disks and components safely cooled.
  • Ease deployment and management
    With an easy web browser interface and a simple setup wizard, the ReadyNAS can be up and running in just minutes. Advanced features like SMART disk pre-failure warnings, scheduled disk scrubbing, and background file system checking and offsite backup ensure data integrity. Email alerts keep you informed wherever you are and auto shutdown options ensure the integrity of your data in case of emergency. X-RAID2 keeps your data protected and allows instant capacity expansion through online background migration to bigger disks.
  • Capable media streaming server
    The ReadyNAS NVX Pioneer Edition is a capable home media server. Monster capacity and lightning performance let you centralize all of your data into one safe place. Streaming services let you experience digital media content locally or over the web with your network DVD player, DVR, Xbox 360, PS3, NETGEAR EVA digital entertainer and more, without the need for a PC.
  • Superior X-RAID2 technology
    ReadyNAS products are dedicated to storage and manage your disks with grace and power, giving you peace of mind protection. X-RAID2 provides invisible, on-the-fly expansion, so you can add capacity without interruption. It eliminates disk reformatting and data shuffling!
  • Multifunciton USB ports
    The ReadyNAS NVX Pioneer Edition has 3 USB 2.0 ports. Share your USB printers by connecting them to the ReadyNAS and using the built-in print server. Hook up external USB hard disks and share them on your network. Or, connect a camera and automatically dump your photos to a safe and central location!
NETGEAR ReadyNAS NVX Pioneer Edition RNDX400E - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
8 TB
13.2 cm x 22.2 cm x 20 cm
4.6 kg ()
Europe
Storage Controller
1 x RAID SATA 3Gb/s RAID 0, 1, 5
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
RAM
1 GB
Microsoft Certification
Compatible with Windows 7
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
8 TB
13.2 cm
22.2 cm
20 cm
4.6 kg ()
Built-in Devices
Status LCD
Europe
Processor / Memory
RAM
1 GB
Storage Controller
1 x RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, RAID 5
Hard Drive
HDD - hot-swap - 3.5" x 1/3H
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
WINS, DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
DHCP support, E-mail alert, print server
Expansion Bays
4 (total) / 4 (free) x hot-swap - 3.5" 1/3H
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 2.0
UL, VCCI, C-Tick, FCC, RoHS
Internal power supply
70 Watt
Power Provided
200 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
20 - 80%
