NETGEAR ReadyNAS 628X (8X4TB ES)
Quicklinx: CZP2WS00 Mfr#: RN628XE4-100NES
  • Xeon
£2,956.78 ex VAT
£3,548.13 inc VAT
ReadyNAS 628X is an 8-bay desktop network storage device, delivering up to 20 Gigabits per second throughput in data backup, file sharing and virtualized storage with a unique 5 Levels of Data Protection, achieving industry leading benchmarks in network data storage and business continuity.
  • File sharing
    These days, running a successful business often depends on successful file sharing - application data, virtual images, client files, email, all the digital files that make your business go. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing, and sharing those critical assets.
  • Backup
    The advanced data protection solution for SMB. Businesses depend on data - customer information, transaction records, pay roll, product development and marketing data. ReadyNAS helps businesses protect their data against physical and human errors, malicious attacks, and natural disasters. Business continuity is part of any business plan.
  • Disaster recovery
    The custom-built ReadyNAS OS protects stored data with automatic RAID configuration, the continuous security of Unlimited Snapshots, and easy to manage Cloud Replication. By maintaining multiple copies of vital data through cloud replication, it makes it easy for you to move data off-site to protect against natural disasters and theft.
NETGEAR ReadyNAS 628X - NAS server - 32 TB
NAS server
Host Connectivity
10 Gigabit Ethernet
Total Storage Capacity
32 TB
Max Supported Capacity
80 TB
8 (installed) / 8 (max)
19.2 cm x 28.855 cm x 31.9 cm
9.38 kg ()
1 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 4 TB Enterprise
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
RAM
8 GB
Storage Operating System
ReadyNAS OS 6.6
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10
5-year warranty
NAS server
Host Connectivity
10 Gigabit Ethernet
32 TB
80 TB
19.2 cm
28.855 cm
31.9 cm
9.38 kg ()
Built-in Devices
2-Line LCD Display, Touch Screen Navigation
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
8 x 4 TB
Enterprise
Network / Transport Protocol
TCP/IP, NTP, iSCSI, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP 2, SNMP 3, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Hardware encryption, wake on LAN (WOL), E-mail alert, IPv6 support, file sharing, event log, Access Control List (ACL) support, iTunes server, Jumbo Frames support, static IP mode, Thin Provisioning, IPv4 support, DLNA Media Server, Apple Time Machine compatible, dynamic IP mode, DHCP client, static routing, cloud managed, Dropbox support, automated backup scheduling, anti-virus protection, Link Aggregation, ReadyCLOUD, 1 fan, Bit Rot Protection
Encryption Algorithm
SSL, TLS, 256-bit AES
IEEE 802.3ad (LACP), UPnP
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA , 2 x Ethernet 10Gb - RJ-45
Security lock slot (cable lock sold separately), UPS support, firmware upgradable, VPN support, X-RAID technology
FCC Class B certified, RoHS, VCCI Class B
Internal power supply
85.6 Watt
Power Provided
250 Watt
ReadyNAS OS 6.6
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
5 - 95% (non-condensing)
Interface: Fast Ethernet
Capacity: 32TB
Interface: 10 Gigabit Ethernet
Interface: Ethernet
Interface: Gigabit Ethernet
Brand: NETGEAR
Price Range Ex VAT: £1500+
