NETGEAR ReadyNAS 4312 2U 10GF (Diskless)
Quicklinx: CHL9WS00 Mfr#: RR4312S0-10000S
  • Xeon
Application data, virtual images, client files, email... the types of data central to running a successful business can seem endless. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing and controlling access to your digital assets. Way more than just simple unified (NAS and SAN) storage for your company, ReadyNAS allows you to do more than you ever thought you could afford by pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication.
Every networked attached storage (NAS) device from NETGEAR runs on the revolutionary ReadyNAS operating system. This custom-built OS protects stored data with X-RAID automatic expansion and offers continuous data protection with unlimited snapshots. Real-time anti-virus and native encryption come standard while 10GbE ports are an option for certain 2U models. Designed specifically for the unique needs of business users, ReadyNAS devices utilize proprietary ReadyCLOUD technology for cloud-based discovery, provisioning and ongoing management. In addition, these devices are virtualization-ready with iSCSI support, thin provisioning capability and certification with VMware and Microsoft.
These days, your data is your world. With ReadyNAS, protecting and accessing that world has never been easier. ReadyNAS - Storage Made EASY.
NETGEAR ReadyNAS 4312S - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
44.5 cm x 70.7 cm x 8.8 cm
11.96 kg ()
1 x Intel Xeon E3-1245V3 3.4 GHz (Quad-Core)
Storage Controller
1 x RAID SATA 6Gb/s / eSATA RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
RAM
16 GB
Power Redundancy
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
44.5 cm
70.7 cm
8.8 cm
11.96 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 128 GB (supported) - DDR4
Flash Memory Installed
256 MB
Storage Controller
1 x RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, NTP, DHCP, Bonjour
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Dynamic IP address assignment, trunking, load balancing, VLAN support, WOL, Syslog support, E-mail alert, IPv6 support, event log, Jumbo Frames support, DLNA Media Server, Apple Time Machine compatible, LACP support, LACP, DHCP client, WebDAV server, anti-virus protection
Encryption Algorithm
SSL, 256-bit AES
IEEE 802.3ad (LACP), UPnP
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 2 x SAS , 2 x eSATA , 2 x Ethernet 10Gb - SFP+
MTBF
159,519 hours
Built-in 3 cooling fans, X-RAID2 technology
FCC Class A certified, RoHS, VCCI Class A
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
163 watt
Power Provided
550 watt
Limited warranty - 5 years
20 - 80% (non-condensing)
Sound Emission
30 dBA
