NETGEAR ReadyNAS 426 (6X4TB ES)
Quicklinx: CZNSWS00 Mfr#: RN426E4-100NES
Capacity: 24TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Atom
£1,713.02 ex VAT
£2,055.62 inc VAT
ReadyNAS 426 enables all the features a smart and modern business is looking for in a single, compact solution: file storage, file sharing, automatic on premise, off-premise or cloud backup and recovery and full data protection. ReadyNAS 426 is built around the next generation Intel Atom Processor C3000 Quad core for high levels of networking throughput enabling enterprise-grade file sharing and data backup for offices up to 40 employees.
  • Automatic Backup & Sync
    "Personal Cloud" on your own hardware - share files, folders and cooperate across sites.
  • 5 levels of protection
    Protect your data from both physical and virtual threats with industry-leading technology and 5 levels of protection.
  • ReadyCLOUD: easy cloud-based set-up, management, and replication
    By far the easiest initial set-up in the industry, ReadyCLOUD lets you discover and manage any ReadyNAS device from the cloud - just plug it into your network, log onto the internet, and set it up with a click of a button. ReadyCLOUD also enables cloud-based replication, simple management and remote file access capabilities.
  • Stop risk before it starts with real time anti-virus & encryption
    In the time between scheduled scans, a virus can slow computers, invade privacy, and damage or steal data. That's why ReadyNAS offers Real-Time Virus and Encryption - a category first. Whenever a file is written to the ReadyNAS, the file is scanned in real-time to stop threats in their tracks. ReadyNAS Encryption also gives you real-time protection, encrypting files as they're written, and by storing keys on a USB dongle rather than in memory or in a file.
  • Continuous data protection
    With unlimited automatic snapshots, ReadyNAS users rest easy knowing they can restore any previous version of a file.
  • Tool-less drive installation
    Add capacity to your ReadyNAS device with no tiny screws or special tools required.
  • Multiple volume support
    ReadyNAS is built with the flexibility needed to grow as business needs evolve.
  • Expands for your growing data
    ReadyNAS is expandable with a library of software add-ons.
NETGEAR ReadyNAS 426 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
24 TB
6 (max)
19.2 cm x 27.7 cm x 25.9 cm
7.43 kg ()
Intel Atom C3000 (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60
Hard Drive
6 x 4 TB Enterprise
10Mb LAN, 100Mb LAN, 1GbE
RAM
2 GB
Storage Operating System
ReadyNAS OS 6.6
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
24 TB
6 (max)
19.2 cm
27.7 cm
25.9 cm
7.43 kg ()
Built-in Devices
2-Line LCD Display, Push Button Navigation
Processor / Memory
Processors Installed
Intel Atom C3000
Number of Cores
Quad-Core
RAM
2 GB DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Hard Drive
HDD - hot-swap
6 x 4 TB
Enterprise
Network / Transport Protocol
TCP/IP, NTP, iSCSI, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP 2, SNMP 3, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Hardware encryption, ALERT notification, wake on LAN (WOL), E-mail alert, IPv6 support, file sharing, event log, Access Control List (ACL) support, iTunes server, Jumbo Frames support, static IP mode, Thin Provisioning, IPv4 support, DLNA Media Server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), dynamic IP mode, DHCP client, cloud managed, Dropbox support, automated backup scheduling, anti-virus protection, Amazon Cloud Drive support, ReadyCLOUD, 1 fan, Bit Rot Protection
Encryption Algorithm
SSL, TLS, 256-bit AES
IEEE 802.3ad (LACP), UPnP
Expansion Bays
6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 1 x eSATA
UPS support, firmware upgradable, VPN support, X-RAID technology
FCC Class B certified, RoHS, VCCI Class B
Internal power supply
63.11 Watt
Power Provided
200 Watt
ReadyNAS OS 6.6
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
45 °C
20 - 80% (non-condensing)
Capacity: 24TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: NETGEAR
Price Range Ex VAT: £1500+
