ReadyNAS 424 is a high performance network data storage solution for small businesses, workgroups, and branch offices of up to 40 employees. With the NETGEAR unique 5 levels of Data Protection, ReadyNAS 424 assures businesses industry’s highest level of data security and reliability, while achieving a new price-performance benchmark in network storage for file serving and data backup.
Automatic backup and sync
"Personal Cloud" on your own hardware - share files, folders and cooperate across sites. -
5 levels of protection
Protect your data from both physical and virtual threats with advanced technology and 5 levels of protection.
- NETGEAR ReadyNAS 424 - NAS server - 16 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Max Supported Capacity
- 40 TB
- Installed Devices / Modules Qty
- 4 (max)
- 18.5 cm x 23.9 cm x 19.4 cm
- 3.95 kg ()
- Processor
- Intel Atom C3338 (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 4 TB Enterprise
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- ReadyNAS OS 6.6
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 40 TB
- 4 (max)
- 18.5 cm
- 23.9 cm
- 19.4 cm
- 3.95 kg ()
- Built-in Devices
- 2-Line LCD Display, Push Button Navigation
Processor / Memory
- Processors Installed
- Intel Atom C3338
- Number of Cores
- Dual-Core
- RAM
- 2 GB DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 4 x 4 TB
- Enterprise
- Data Link Protocol
- TCP/IP, NTP, iSCSI, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP 2, SNMP 3, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Hardware encryption, ALERT notification, wake on LAN (WOL), E-mail alert, IPv6 support, file sharing, event log, Access Control List (ACL) support, iTunes server, Jumbo Frames support, static IP mode, Thin Provisioning, IPv4 support, DLNA Media Server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), dynamic IP mode, DHCP client, cloud managed, Dropbox support, automated backup scheduling, anti-virus protection, Amazon Cloud Drive support, ReadyCLOUD, 1 fan, Bit Rot Protection
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- IEEE 802.3ad (LACP), UPnP
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 1 x eSATA
- UPS support, firmware upgradable, VPN support, X-RAID technology
- FCC Class B certified, RoHS, VCCI Class B
- Power Device
- External power adapter
- Voltage Required
- 43.09 Watt
- Power Provided
- 90 Watt
- ReadyNAS OS 6.6
- OS Required
- Limited warranty - replacement - 5 years - response time: next business day ¦ Technical support - 90 days
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
