Application data, virtual images, client files, email... the types of data central to running a successful business can seem endless. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing and controlling access to your digital assets. Way more than just simple unified (NAS and SAN) storage for your company, ReadyNAS allows you to do more than you ever thought you could afford by pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication.
Every networked attached storage (NAS) device from NETGEAR runs on the revolutionary ReadyNAS operating system. This custom-built OS protects stored data with X-RAID automatic expansion and offers continuous data protection with unlimited snapshots. Real-time anti-virus and native encryption come standard while 10GbE ports are an option for certain 2U models. Designed specifically for the unique needs of business users, ReadyNAS devices utilize proprietary ReadyCLOUD technology for cloud-based discovery, provisioning and ongoing management. In addition, these devices are virtualization-ready with iSCSI support, thin provisioning capability and certification with VMware and Microsoft.
These days, your data is your world. With ReadyNAS, protecting and accessing that world has never been easier. ReadyNAS - Storage Made EASY.
- NETGEAR ReadyNAS 3312 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Max Supported Capacity
- 72 TB
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 44.5 cm x 70.7 cm x 8.8 cm
- 11.96 kg ()
- Processor
- 1 x Intel Xeon E3-1225V5 3.3 GHz (Quad-Core)
- Storage Controller
- 1 x RAID SATA 3Gb/s RAID 0, 1, 5, 6, 10
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 72 TB
- 44.5 cm
- 70.7 cm
- 8.8 cm
- 11.96 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 8 GB DDR4
Storage Controller
- 1 x RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
- Data Link Protocol
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 2 x SAS , 2 x eSATA
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- Power Provided
- 550 watt
- Limited warranty - 5 years
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.03 |
