NETGEAR ReadyNAS 3138 16TB (4x4TB) Rackmount
Quicklinx: BYM8WS00 Mfr#: RN31844E-100NES
  • Atom
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Application data, virtual images, client files, email… the types of data central to running a successful business can seem endless. ReadyNAS is that advanced and easy-to-use solution for centralizing, securing and controlling access to your digital assets. More than just simple unified (NAS and SAN) storage, ReadyNAS lets you to do more than you ever thought you could afford - pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication. Designed for the unique needs of SMB, the ReadyNAS Rackmount Series combines advanced features with simple, efficient management.
  • Worry-free long-term data storage with Bitrot Protection
    BTR-filesystem based checksum algorithms protect files from degradation/corruption over time.
  • Minimized human error
    Unlimited data snapshot capability allows the restore of deleted files from previous points in time in hourly intervals.
  • Easy capacity expansion
    XRAID2 & Instant Provisioning.
  • Easy protection against disasters and for branch offices
    Web-managed replication to backup data to a second NAS with minimum configuration effort.
  • Ready for virtual infrastructures
    iSCSI, Thin Provisioning and high performance.
  • Protected against outside threats
    Anti-virus & Encryption.
  • Secure remote access with own VPN (optional)
    Modern GUI and Cloud/Remote Access from anywhere for collaboration, sharing and management.
  • Disaster Recovery
    Web-managed replication for easy and fast restore in case of disaster.
  • Virtualization
    Thin provisioning, iSCSI support and certified with Microsoft.
  • File Server
    Unified storage platform for sharing files under Windows, Mac and Linux - with on-board hourly protection.
  • Backup
    RAID redundancy with automatic expansion, high performance and best-in-class warranty. compatible with all major backup Software.
  • Surveillance
    Works as a NVR with all major surveillance software or use ReadyNAS surveillance app for up to 128 cameras.
NETGEAR ReadyNAS 3138 RN31844E - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
16 TB
Max Supported Capacity
32 TB
4 (installed) / 4 (max)
48.6 cm x 40.6 cm x 4.4 cm
United States, Europe
1 x Intel Atom C2558 2.4 GHz (Quad-Core)
Storage Controller
RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 4 TB Enterprise
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
16
RAM
4 GB
Storage Operating System
ReadyNAS OS 6.4
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Microsoft Windows 7 (32/64 bits), Oracle Solaris, Apple iOS, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
16 TB
32 TB
48.6 cm
40.6 cm
4.4 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
4 GB
Flash Memory Installed
128 MB
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 4 TB
Enterprise
Network / Transport Protocol
TCP/IP, NTP, DHCP, Bonjour
Remote Management Protocol
SNMP 2, SNMP 3, HTTP
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Dynamic IP address assignment, trunking, load balancing, WOL, IPv6 support, event log, ACL support, SSH support, iTunes server, Jumbo Frames support, surveillance station, DLNA Media Server, Apple Time Machine compatible, DHCP client, static routing, cloud managed, Dropbox support, 3 fans, anti-virus protection
Encryption Algorithm
256-bit AES
IEEE 802.3ad (LACP), UPnP
Security DVR
16
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 2 x eSATA
1 x network cable
Built-in 3 cooling fans, X-RAID2 technology
FCC Class B certified, RoHS, VCCI Class B
Internal power supply
Installed Qty
1
Max Supported Qty
1
38 watt
Power Provided
180 watt
ReadyNAS OS 6.4
Limited warranty - replacement - 5 years - response time: next business day , Technical support - phone consulting - 90 days , Technical support - web support - lifetime
5 - 95% (non-condensing)
Sound Emission
28 dBA
