NETGEAR ReadyNAS 2304 1U 4Bay GBE 4TB (ES)
Quicklinx: CZP7WS00 Mfr#: RR2304G4-100NES
Capacity: 16TB
Interface: Fast Ethernet, Ethernet, Gigabit Ethernet
  • Celeron
£1,418.70 ex VAT
£1,702.44 inc VAT
Comes prepopulated with 4 x 4TB hard drives.
ReadyNAS 2304 offers the ideal solution to a small and medium size business (SMB) that requires file serving and data backup to support teams of up to 40 employees. The RR2304 supports the entire suite of features in ReadyNAS OS, including 5 levels of data protection, ReadyDR disaster recovery, and virtualized storage for VMware and other virtualized networks.
Powered by a dual core Intel CPU, the RR2304, features a dual Gigabit Ethernet interface, delivers over 2x the data throughput of its predecessor, the RN2120, with significant processing capacity headroom. The superior hardware architecture enables the RR2304 to perform all business applications in the ReadyNAS OS, including ReadyDR, a block level backup solution for disaster recovery, as well as ReadyNAS Milestone VMS, a surveillance video management system.
NETGEAR ReadyNAS 2304 - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
16 TB
Max Supported Capacity
40 TB
4 (installed) / 4 (max)
43 cm x 30.8 cm x 4.4 cm
4.19 kg ()
Intel Celeron 2 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 4 TB
10Mb LAN, 100Mb LAN, 1GbE
RAM
2 GB
Storage Operating System
ReadyNAS OS 6.7 or later
UNIX, Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
16 TB
40 TB
43 cm
30.8 cm
4.4 cm
4.19 kg ()
Processor / Memory
Processors Installed
Intel Celeron 2 GHz
Number of Cores
Dual-Core
RAM
2 GB
Flash Memory Installed
128 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
4 x 4 TB
Network / Transport Protocol
TCP/IP, NTP, iSCSI, FTP, DHCP, Bonjour, SMB
Remote Management Protocol
SNMP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Wake on LAN (WOL), E-mail alert, IPv6 support, Access Control List (ACL) support, SSH support, Jumbo Frames support, static IP mode, IPv4 support, DLNA Media Server, Apple Time Machine compatible, dynamic IP mode, DHCP client, WebDAV server, Dropbox support, anti-virus protection, 3 fan trays, ReadyCLOUD
Encryption Algorithm
SSL, TLS, 256-bit AES
IEEE 802.3ad (LACP), UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 , 1 x DisplayPort
X-RAID2 technology, LED indicator, built-in cooling fan, UPS support, auto shutdown circuit, VPN support, one-touch copy button, S.M.A.R.T. support
FCC Class B certified, RoHS, AES-256, VCCI Class B
Internal power supply
47.5 Watt
Power Provided
180 Watt
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
45 °C
20 - 80% (non-condensing)
Capacity: 16TB
Interface: Ethernet
Interface: Gigabit Ethernet
Brand: NETGEAR
Price Range Ex VAT: £1000 - £1500
