The ReadyNAS 210 is powered by a quad core Cortex A15 1.4GHz processor, has 2 Gigabytes of RAM, dual Gigabit Ethernet ports with Link Aggregation technology and delivers up to 200MByte/sec data transfer speed. It offers the industry’s leading feature of 5 levels of protection on your documents, photos, videos and all types of data. The ReadyCLOUD portal-based user interface and app on PC, Mac, smartphones and tablets make the RN210 the ideal choice for consumers because of its simplicity and ease of use.
- NETGEAR ReadyNAS 214 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 4 (max)
- 22 cm x 10.1 cm x 14.2 cm
- 2.03 kg ()
- Processor
- 1 x Cortex-A15 1.4 GHz (Quad-Core)
- Storage Controller
- 1 x RAID SATA 3Gb/s RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- ReadyNAS OS 6.2
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Android, Microsoft Windows 7 (32/64 bits), Apple iOS, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 4 (max)
- 22 cm
- 10.1 cm
- 14.2 cm
- 2.03 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 2 GB
- Flash Memory Installed
- 128 MB
Storage Controller
- 1 x RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- TCP/IP, NTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP 2, SNMP 3, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- WOL, E-mail alert, IPv6 support, ACL support, SSH support, Jumbo Frames support, static IP mode, IPv4 support, dynamic IP mode, DHCP client, WebDAV server, Dropbox support, anti-virus protection
- Encryption Algorithm
- 256-bit AES
- IEEE 802.3ad (LACP), UPnP
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 , 1 x eSATA
- Security lock slot (cable lock sold separately), X-RAID2 technology, LED indicator, built-in cooling fan, UPS support, auto shutdown circuit, VPN support, one-touch copy button
- FCC Class B certified, RoHS, AES-256, VCCI Class B
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 60 Watt
- ReadyNAS OS 6.2
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
