NETGEAR ReadyNAS 2120 4-Bay NAS Storage (Diskless)
Quicklinx: B63MWS00 Mfr#: RN2120-200NES
Application data, virtual images, client files, email... the types of data central to running a successful business can seem endless. With ReadyNAS you finally have an advanced and easy-to use solution for centralizing, securing and controlling access to your digital assets. Way more than just simple unified (NAS and SAN) storage for your company, ReadyNAS allows you to do more than you ever thought you could afford by pairing the latest in performance with innovative efficiency technologies such as unlimited snapshots, thin provisioning and cloud-managed replication.
Every networked attached storage (NAS) device from NETGEAR runs on the revolutionary ReadyNAS 6 operating system. This custom-built OS protects stored data not only with automatic RAID configuration, but is the first of its kind to feature the continuous data protection of unlimited snapshots along with real-time anti-virus and native encryption. Designed with ease-of-use in mind, ReadyNAS devices utilize proprietary ReadyCLOUD technology for cloud-based discovery, provisioning and even ongoing management.
  • Unlimited snapshots
    Unlimited data snapshot capability for on-box protection and flexible data recovery.
  • iSCSI and thin provisioning
    Powerful tool is design for a businesses taking advantage of virtual infrastructures.
  • XRAID2 & instant provisioning
    Easily expand capacity and feel confident knowing that data is always protected.
  • Anti-virus & encryption
    Keep data protected from outside threats and safe from prying eyes.
  • Cloud-managed replication
    Maintain data sets in multiple locations or ensure protection of data from remote or branch office locations.
  • Modern GUI and ReadyCLOUD management
    Sleek, modern interface that puts the tools you need, where and when you need them.
NETGEAR ReadyNAS 2120 RN2120v2 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
24 TB
0 (installed) / 4 (max)
28.5 cm x 34 cm x 4.4 cm
4.19 kg ()
1 x Marvell ARMADA XP 1.6 GHz (Dual-Core)
Storage Controller
1 x RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
Automatic backup, Exclusive-OR (XOR), Data Protection Technology
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
ReadyNAS OS 6
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
24 TB
28.5 cm
34 cm
4.4 cm
4.19 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
2 GB DDR3
Flash Memory Installed
128 MB
Storage Controller
1 x RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 2.5" / 3.5" shared
S.M.A.R.T.
Network / Transport Protocol
TCP/IP, NTP, SMTP, FTP, DHCP, Bonjour, SMB, NFS
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Load balancing, VLAN support, wake on LAN (WOL), IPv6 support, server health monitoring, file sharing, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, static IP mode, Thin Provisioning, bandwidth control, IPv4 support, Apple Time Machine compatible, LACP support, Link Aggregation Control Protocol (LACP), dynamic IP mode, DHCP client, WebDAV server, static routing, cloud managed, Dropbox support, NAS support, anti-virus protection
Encryption Algorithm
SSL, TLS, 256-bit AES
IEEE 802.3ad (LACP), DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 , 1 x USB 2.0 , 2 x eSATA
Automatic server restart (ASR), remote control, application snapshots, built-in 3 cooling fans, X-RAID2 technology, LED indicator, UPS support, volume control, software encryption, auto shutdown circuit, VMware Ready, VPN support
FCC Class B certified, RoHS, VCCI Class B, TLS
Internal power supply
38 Watt
ReadyNAS OS 6
Limited warranty - 5 years
5 - 95% (non-condensing)
B63M C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
B63M C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
