NetGear ReadyNas 2100 4TB Network Attached Storage (4x1TB)
Quicklinx: 5LB6WS00 Mfr#: RNRX4410-100EUS
The ReadyNAS 2100 is a 1U 4-bay storage system designed for workgroups and small businesses. It is a high-quality solution for storing, sharing and protecting business-critical data that is affordable for the smallest office. ReadyNAS unified architecture solves numerous data management problems with a single system, making capacity management, access, backup, restore and disaster recovery worries obsolete. Now you can eliminate common data concerns and revolutionize your storage environment without becoming an expert.
  • Store
    Centralize data from your local systems into one single storage device, reducing management headaches and instantly increasing reliability. Capacity can be added with zero downtime, and ReadyNAS supports both file sharing and server applications.
  • Share
    Access data no matter where you are - from multiple computers, on the road, or in an alternate office location. Safely deliver or present your work to customers and clients without email or FTP headaches! The ReadyNAS Remote feature means drag-and-drop over a secure connection between any computer and your ReadyNAS. No more firewall, VPN or awkward Web-based remote access solutions.
  • Protect
    Successful businesses understand that lost information means lost revenue. Multiple layers of protection are built into every ReadyNAS, including drive fault tolerance, online backups (snapshots), and secure offsite replication to another ReadyNAS system. A ReadyNAS revolutionizes backup and recovery times and can replace tape completely, making offsite replication and backup a complete, affordable and timely reality for small business users.
NETGEAR ReadyNAS 2100 RNRX4410 - NAS server - 4 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
4 TB
4 (installed) / 4 (max)
43 cm x 31.8 cm x 4.3 cm
9.5 kg ()
Europe
Storage Controller
1 x RAID SATA 3Gb/s RAID 0, 1, 5
Hard Drive
4 x 1 TB
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
1 GB
Storage Operating System
RAIDiator OS
Microsoft Certification
Compatible with Windows 7
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
4 TB
43 cm
31.8 cm
4.3 cm
9.5 kg ()
Europe
Processor / Memory
RAM
1 GB
Storage Controller
1 x RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, RAID 5
Hard Drive
HDD - hot-swap - 3.5" x 1/3H
4 x 1 TB
Remote Management Protocol
SNMP, HTTP
Network Services Compatibility
Microsoft Active Directory (AD), WINS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Dynamic IP address assignment, DHCP support, E-mail alert, print server, DHCP server
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5" 1/3H
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 2.0
UL, VCCI, C-Tick, FCC, RoHS
Internal power supply
80 Watt
RAIDiator OS
Limited warranty - 5 years
20 - 80%
