NETGEAR ReadyNAS" 3100, 4-bay 1U 4x2tb
Quicklinx: 78H6WS00 Mfr#: RNRP4420-100EUS
The ReadyNAS 3100 is a 1U 4-bay storage system designed for those seeking reliable and affordable server virtualization and file storage. The ReadyNAS unified architecture supports both NAS and SAN applications and solves numerous data management problems with a single system. Redundant power supplies deliver high reliability. Integrated data protection and offsite replication features make managing complex business storage environments affordable.
  • Store
    Centralize data from multiple local systems into one single storage device, reducing management overhead and instantly increasing reliability. Capacity can be added with zero downtime, and ReadyNAS supports file sharing and server virtualization applications like Microsoft Hyper-V, VMware or Citrix XenServer.
  • Share
    Serve files to Windows, Macintosh and Linux/UNIX users simultaneously. Access data no matter where you are - from multiple computers, on the road, or in an alternate office location. Consolidate and eliminate file servers while hosting virtual machines at the same time. Elegantly manage capacity across your servers and clients all at the same time. The ReadyNAS remote feature means drag-and-drop over a secure connection between any computer and your ReadyNAS. No more firewall, VPN or awkward web-based remote access solutions.
  • Protect
    Successful businesses understand that lost information means lost revenue. Multiple layers of protection are built into every ReadyNAS, including drive fault tolerance, redundant power supply, online backups, and secure offsite replication to another ReadyNAS system. A ReadyNAS revolutionizes backup and recovery times and can replace tape completely, making offsite replication and backup a complete, affordable and timely reality for small business users.
NETGEAR ReadyNAS 3100 RNRP4420 - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
8 TB
4 (installed) / 4 (max)
43.7 cm x 65 cm x 4.3 cm
19.9 kg ()
Europe
1 x Intel
Storage Controller
1 x RAID SATA 3Gb/s RAID 0, 1, 5
Hard Drive
4 x 2 TB
Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
RAM
2 GB
Power Redundancy
Storage Operating System
RAIDiator OS
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
8 TB
43.7 cm
65 cm
4.3 cm
19.9 kg ()
Europe
Processor / Memory
Processors Installed
1 x Intel
RAM
2 GB
Storage Controller
1 x RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive
Max Storage Devices Qty
4
RAID Level
RAID 0, RAID 1, RAID 5
Hard Drive
HDD - hot-swap - 3.5" x 1/3H
4 x 2 TB
Network / Transport Protocol
DHCP
Remote Management Protocol
SNMP, HTTP, HTTPS, FTP
Network Services Compatibility
Microsoft Active Directory (AD), WINS, DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Dynamic IP address assignment, DHCP support, load balancing, VLAN support, WOL, E-mail alert, IPv6 support, event log, DHCP server, static IP mode, temperature sensor
IEEE 802.3ad (LACP)
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5" 1/3H
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0
VCCI, C-Tick, CCC, FCC, RoHS, KCC, WEEE
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
150 Watt
Power Provided
450 Watt
RAIDiator OS
Limited warranty - 5 years
20 - 80%
