NetGear ReadyDATA EDA4000 System 4U 24 Bay Storage Empty Chassis #
Quicklinx: 84JPWS00 Mfr#: EDA4000-100WWS
ReadyDATA redefines the concept of storage for small and medium businesses, remote offices/branch offices (ROBO), and departments within enterprise organizations. The ReadyDATA EDA4000 adds expansion capability to the ReadyDATA 5200 product family with 24-bays of storage in 4U form factor. The ReadyDATA family of unified storage was built with the needs of a growing business in mind. Each ReadyDATA 5200 can support up to two ReadyDATA EDA4000 using the 6G SAS expansion ports. For meeting the differing needs of specific applications, ReadyDATA users can mix and match SATA, near-line SAS, SAS, and SSD drives within volumes to provide optimal performance. Also, new drives can be easily added while the system is running for seamless expansion on-the-fly.
NETGEAR ReadyDATA 4U Expansion Chassis EDA4000 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 4U
Max Supported Capacity
72 TB
SAS
0 (installed) / 24 (max)
Supported Drives
SATA-300 / SAS
Storage Controller
RAID RAID RAID 0, 1, 5, 6, 10
AC 120/230 V - 50 - 60 Hz
Power Redundancy
43.7 cm x 66 cm x 17.8 cm
5-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 4U
Chassis
0
Supported Devices / Modules Qty
24
Supported Drives
SATA-300 / SAS
Storage
72 TB
HDD Array External Interface
SAS
Storage Controller
RAID - integrated (SATA-300 / SAS)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Expansion Bays
24 (total) / 24 (free) x hot-swap
VCCI, C-Tick, CCC, FCC, RoHS, KCC
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
700 Watt
43.7 cm
66 cm
17.8 cm
Limited warranty - 5 years , Limited warranty - advance parts replacement - 3 years - on-site
20 - 80% (non-condensing)
