NetGear RangeMax Wireless-N USB 2.0 Adapter
Quicklinx: 536RWS00 Mfr#: WNDA3100-100GES
  • Wi-Fi CERTIFIED
  • IEEE 802.11n (draft 2.0)
The NETGEAR RangeMax Dual Band Wireless-N USB 2.0 Adapter WNDA3100 delivers consistent wireless connections using 5 GHz Wireless-N. It works with both 5 GHz and dual band Wireless-N Gateways, Routers and Access Points.
NETGEAR RangeMax WNDA3100 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
3 cm x 9.5 cm x 1.5 cm
22 g
802.11a, 802.11b/g, 802.11n (draft 2.0)
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Microsoft Windows Vista / XP
Microsoft Certification
Certified for Windows Vista
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Software Included
Drivers & Utilities, NETGEAR Smart Wizard
System Requirements Details
Pentium - 300 MHz
3 cm
9.5 cm
1.5 cm
22 g
