NetGear RangeMax Wireless-N Gigabit DSL Router
Customer rating: 2.0* (Write a review)
Quicklinx: 5834WS00 Mfr#: WNR3500-100UKS
  • Wi-Fi CERTIFIED
  • IEEE 802.11n (draft 2.0)
Built-in ultra fast 4-port gigabit switch means even faster network performance! Surf, email, stream HD video, on-line game, make Internet phone calls simultaneously with the NETGEAR RangeMax Wireless-N Gigabit Router WNR3500. It features Automatic Quality of Service (QoS) that ensures reliable Internet, voice, video, and gaming applications.
NETGEAR RangeMax WNR3500 - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Remote Management Protocol
HTTP
Firewall protection, NAT support, SPI, DoS attack prevention, IDS, VPN passthrough, URL filtering, firmware upgradable, QoS, WPS
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
17.2 cm x 3.9 cm x 22.6 cm
0.56 kg
Microsoft Certification
Works with Windows Vista
UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
English / United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 ¦ WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Directivity
Omni-directional
External power adapter
Vertical stand
1 x network cable
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Software Included
Drivers & Utilities
17.2 cm
3.9 cm
22.6 cm
0.56 kg
Resources
The following resources are available for the NetGear RangeMax Wireless-N Gigabit DSL Router
Customer reviews
Write a review for the NetGear RangeMax Wireless-N Gigabit DSL Router here!
N stands for Not Working
Reviewed by Robin. Review Posted 11/03/2009
It's easy to set up, but then you have to wonder why you bothered.
The range is good, can't fault it there, but the performance is terrible.
I used this to replace another Netgear router, a standard 802.11g model.
I wish I hadn't. Web pages loaded slower than ever, downloads never got above 50k a second and yet the connection to the router was always fine.
Plugging in the old one again just to be sure it wasn't just my internet connection, webpages once again loaded instantly and my downloads were back up to the 700k a second that I was used to.
Terrible router, a quick search on the internet shows that other people also experience the same thing.
  • Overall 2*
  • Ease of use 4*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
