NETGEAR RangeMax Dual Band Wireless-N For Cable Users
Quicklinx: 69LXWS00 Mfr#: WNDR3700-100UKS
  • IEEE 802.11n (draft 2.0)
The NETGEAR RangeMax Dual Band Wireless-N Gigabit Router delivers the ultimate in wireless performance for home and small business networking. With twice the available bandwidth, separate Wireless-N access points for media/gaming and data, and concurrent dual band N, you will enjoy the most reliable wireless connections for HD media streaming, gaming, and maximum Internet bandwidth. Along with four gigabit Ethernet ports enabling maximum wired speeds, this full featured high performance router is an ideal solution for the connected home with multiple computers and network enabled gadgets running multiple applications at the same time.
Centralizing an external storage device and file sharing is easy. Simply connect your USB storage device to the back port of your Dual Band router, and every computer on your network can now access the USB Storage device, easily exchanging media, documents, music, and more. The dual band gigabit router prioritizes network traffic efficiently, ensuring high quality of experience for video streaming, VoIP, online gaming and other critical tasks.
NETGEAR RangeMax WNDR3700 - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Remote Management Protocol
HTTP
Firewall protection, SPI, DoS attack prevention, QoS, WPS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Environmental Standards
ENERGY STAR Qualified
22.3 cm x 15.3 cm x 3.1 cm
0.5 kg
Microsoft Certification
Compatible with Windows 7
UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Radio Service Set ID (SSID)
MIPS 680 MHz
RAM
64 MB
Flash Memory
8 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
8
External power adapter
ENERGY STAR Certified
Vertical stand
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
22.3 cm
15.3 cm
3.1 cm
0.5 kg
Limited warranty - 1 year
69LX C2G 2m USB 2.0 A/B Cable - Black In Stock £3.57
