NetGear R8000-100UKS Nighthawk X6 4port AC3200 Wifi Router
Quicklinx: B5SSWS00 Mfr#: R8000-100UKS
Type: Wireless router
Connection Type: DSL (Cable)
Standards: IEEE 802.11g, Ethernet, IEEE 802.11b, IEEE 802.11n + 4 more
Speed: 3.2Gbps
Rackmount or External: External
  • IEEE 802.11n
£163.50 ex VAT
£196.20 inc VAT
There's never been Wi-Fi like it. The Nighthawk X6 AC3200 Router with breakthrough Tri-Band Wi-Fi technology was built to connect to each and every device in your home - automatically and simultaneously. Laptops, tablets, phones, TVs, game consoles, music streamers, cameras - if it's Wi-Fi enabled, it's X6 accelerated. With a massive combined wireless speed of up to 3.2Gbps, 3 Wi-Fi bands and Smart Connect intelligence, every device is assigned the fastest Wi-Fi connection possible and optimized for maximum speed.
  • Tri-Band Wi-Fi
    Tri-Band Wi-Fi with Smart Connect changes the game for today's home Wi-Fi networks. With one 2.4GHz band and two 5GHz Wi-Fi bands to work with, the X6 has the capacity, flexibility, and intelligence to assign each device to the Wi-Fi band where it can connect at its maximum possible speed. The result is that faster devices can connect and perform unhindered by slower or older devices - meaning ALL devices load, stream, and game at their maximum speed.
  • More Wi-Fi range for more devices
    Keep your mobile device connected throughout your home with powerful amplifiers and 6 high performance external antennas. Roam freely and enjoy strong Wi-Fi coverage and performance anywhere in your home. The 6 antennas deliver the breakthrough X6 Tri-Band Wi-Fi and Beamforming+ focuses Wi-Fi signals creating stronger and more reliable connections for all to enjoy.
  • ReadySHARE USB - ready to store and share
    ReadySHARE USB opens up a powerful set of convenient features like USB storage access and streaming media. With the available USB 3.0 and USB 2.0 ports on the X6 you can connect the USB storage you already own and enjoy high-speed access via Wi-Fi.
  • Safeguard your files with no worry backups
    FREE ReadyShare Vault PC software it there for you to schedule automatic hassle-free backups to safeguard precious photos and files from any PC directly to the connected USB storage. ReadyShare Vault is FREE to download and use with your Nighthawk X6.
  • Better processors
    What could you do with more speed? More power? With a fast dual core processor and three offload processors, the Nighthawk X6 delivers faster Wi-Fi speed, faster wired speed, faster USB access speed, and faster WAN-to-LAN speeds meaning faster overall network speeds than ever before. So go ahead and put this network to the test in your home.
NETGEAR Nighthawk X6 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.2 Gbps
Remote Management Protocol
HTTP
Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, firmware upgradable, Wi-Fi Protected Setup (WPS), ReadySHARE, Push ā€˜N’ Connect button, DLNA Media Server, Beamforming+, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
29.55 cm x 22.68 cm x 5.45 cm
1.1 kg
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.2 Gbps
HTTP
Encryption Algorithm
WPA-PSK, WPA2-PSK
1 GHz
RAM
256 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
6
External power adapter
1 x network cable
United Kingdom
Software Included
NETGEAR Genie
29.55 cm
22.68 cm
5.45 cm
1.1 kg
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Standards: Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11ac
Speed: 3.2Gbps
Brand: NETGEAR
