NetGear R6300 WiFi Router 802.11ac Dual Band Gigabit
Quicklinx: 89D3WS00 Mfr#: R6300-100UKS
  • IEEE 802.11n
The NETGEAR R6300 Wi-Fi Router delivers next generation WiFi at Gigabit speeds. It offers the ultimate mobility for Wi-Fi devices with speeds up to 3x faster than 802.11n. Compatible with next generation Wi-Fi devices and backward compatible with 802.11 a/b/g and N devices, it enables HD streaming throughout your home. The R6300 with simultaneous dual band Wi-Fi technology avoids interference, ensuring top Wi-Fi speeds and reliable connections. This makes it ideal for larger homes with multiple devices. In addition, four Gigabit Ethernet ports offer ultra-fast wired connections. Wirelessly access and share USB hard drive and USB printer using the two USB 2.0 ports. The NETGEAR Genie app provides easy installation from an iPad, tablet, computer or smartphone. It includes a personal dashboard, allowing you to manage, monitor, and repair your home network.
  • Enhanced security
    With support for WPA, WPA-PSK, WPA2, and WPA2-PSK encryption algorithms, this NETGEAR R6300 wireless router ensures your network remains secure against unauthorized access.
  • Versatile connectivity
    Featuring Ethernet 10Base-T/100Base-TX/1000Base-T interfaces along with wireless 802.11a/b/g/n/ac protocols, the router offers flexible connection options for both wired and wireless devices.
  • Dual-band technology
    The 2.4 GHz and 5 GHz Wi-Fi bands provide enhanced bandwidth to support more devices, reduce interference, and offer better connection quality.
  • Comprehensive control
    Equipped with features like parental control, Quality of Service (QoS), and a Push ‘N' Connect button, this router allows for easy management of your network's access and bandwidth distribution.
  • Easy sharing
    ReadySHARE and a USB 2.0 port make it simple to share printers, files, and media across your network, enhancing productivity and entertainment options.
NETGEAR R6300 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Firewall protection, auto-sensing per device, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Green Ethernet, ReadySHARE, Push ‘N’ Connect button, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
20.5 cm x 25.5 cm x 7.7 cm
654 g
Microsoft Certification
Compatible with Windows 7
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
RAM
128 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x network cable
United Kingdom
Software Included
NETGEAR Genie
20.5 cm
25.5 cm
7.7 cm
654 g
Limited warranty - 1 year
89D3 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
89D3 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
