NETGEAR QUAD WAN SSL GIGABIT VPN FIREWALL
Quicklinx: 71PMWS00 Mfr#: SRX5308-100EUS
The flagship model of the ProSafe firewall family - the SRX5308 is perfect for even the most demanding business networks. The SRX5308 features a hardware-accelerated data flow architecture that allows for 1 Gbps of stateful firewall throughput. This powerful VPN router is a high-performance, SNMP-manageable, network solution that furnishes multidimensional security including denial-of-service (Dos) protection, stateful packet inspection (SPI), URL keyword filtering, configurable hardware DMZ port, logging, reporting, and real-time alerts. QoS, WAN traffic metering, and bandwidth profiling gives you granular bandwidth management capabilities. VLAN support allows you to separate guest traffic from critical production servers. Four Gigabit LAN ports allows for maximum internal data transfer speeds, while the four Gigabit WAN ports provide two modes of session-based load-balancing as well as failover protection to ensure maximum throughput and reliable connectivity to the Internet.
NETGEAR ProSafe SRX5308 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
4
Performance
Throughput: 924 Mbps , VPN throughput (3DES IPSec): 180 Mbps , VPN throughput (SSL): 21 Mbps
Concurrent connections: 200000 , IPSec VPN tunnels: 125 , SSL VPN tunnels: 50 , Virtual interfaces (VLANs): 254
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, NTP, IPSec, PPPoE, DHCP
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS
DMZ port, DHCP support, NAT support, PAT support, load balancing, LDAP support, VLAN support, Syslog support, SPI, DoS attack prevention, content filtering, WRR queuing, VPN passthrough, firmware upgradable, QoS, port forwarding
IEEE 802.1Q
33 cm x 20.9 cm x 4.3 cm
2.1 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
X.509 certificates, Active Directory
IEEE 802.1Q, VCCI, cUL, RoHS, FCC CFR47 Part 15, C-Tick Class A, CEE Tier 3
RAM
512 MB SDRAM
Flash Memory
64 MB
WAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
1 x network cable
Rack Mounting Kit
Included
Europe
Software Included
Drivers & Utilities, ProSafe VPN Client
33 cm
20.9 cm
4.3 cm
2.1 kg
45 °C
0 - 90%
