NetGear Prosecure UTM5 Appliance + 1 Year Support
Quicklinx: 6P07WS00 Mfr#: UTM5EW-100EUS
The ProSecure UTM series of all-in-one gateway security appliances combine best-of-breed security technologies and Stream Scanning technology to protect businesses against today's Web, email, and network threats. Malware hosted on Web pages, phishing attacks, spam, virus infected emails, hackers, denial-of-service attacks, and other threats are now all part of a regular repertoire of sophisticated blended attacks that bypass traditional firewalls with ease. Growing businesses have been the ones most seriously affected as they, unlike their enterprise counterparts, often lack the time and resources to fully harden and secure their networks from these threats.
ProSecure Unified Threat Management (UTM) appliances combine performance with comprehensive security coverage. Patent-pending Stream Scanning technology enables the use of an extensive virus and malware database while maintaining a high level of throughput and minimizing scanning-induced latency. The flexible modular software design architecture leverages Stream Scanning technology to scan files and data streams up to 5x faster than conventional methods. This architecture in turn enables the ProSecure UTM to utilize virus and malware threat databases from ProSecure and Sophos that are over one million signatures in size - up to 400x more comprehensive than legacy all-in-one platforms. This architecture, combined with best-of-breed hybrid in-the-cloud Web filter and anti-spam technologies along with proven firewall and VPN functionality, form the ideal growing business gateway security solution.
Given the high performance requirements of scanning latency sensitive Web traffic, incorporating enterprise-grade security software technologies onto traditional all-in-one platforms has been a very difficult task. That is why the ProSecure UTM features Stream Scanning technology which analyses data streams as they enter the network. The ProSecure Stream Scanning approach is many times faster than that of more traditional batchbased scanning methods where the entire file is buffered before it is scanned. Due to its nature, traditional batch-based scanning methods introduce latency to network traffic. While latency is more tolerable for email traffic, for large amounts of HTTP Web traffic, such latency often slows Web browsing to a crawl. All-in-one solutions in the past have tried to overcome the latency issue by minimizing the malware signature set, scanning only a handful of file types, or by avoiding Web traffic scanning altogether. This approach exposes an entire vector of the network to malware-based.
The ProSecure UTM will easily replace any existing firewall or router. A simple 10-step setup wizard guides you through installation and the UTM will be up and running in minutes. Administration is performed through an intuitive Web-based interface. Set granular policies and alerts, check summary statistics and graphical reports, drill down to IP address-level data, and integrate log data with standard network management tools using SNMP. Malware and IPS signature, software, and firmware updates are all handled by the UTM - online and automatically.
  • Unified gateway security for growing businesses - without compromise
  • All-in-one network security
  • Revolutionary stream scanning platform
  • Simple setup, ease of management
NETGEAR ProSecure Unified Threat Management Appliance UTM5 - security appliance - with 1 year Web, 1 year Email, and 1 year Software Maintenance and Upgrades, 24/7 Support, and Advanced Replacement
Security appliance
Bundled Services
External
Europe
RAM
512 MB
Flash Memory
2 GB
Ports Qty
4
Performance
Antivirus throughput: 15 Mbps , Stateful throughput: 90 Mbps , VPN throughput: 40 Mbps
Concurrent users: 1 - 5 , Concurrent connections: 8000 , Virtual interfaces (VLANs): 255 , VPN tunnels (site-to-site): 5 , VPN tunnels (remote access): 2
33 cm x 20.9 cm x 4.3 cm
2.1 kg
Security appliance
Bundled Services
33 cm
20.9 cm
4.3 cm
2.1 kg
Europe
Processor / Memory / Storage
RAM
512 MB
Flash Memory
2 GB
External
Ports Qty
4
Wired
Network / Transport Protocol
PPTP, PPPoE, DHCP
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 2c, HTTP, HTTPS
Performance
Status Indicators
Port transmission speed, power, test mode, link/activity
Firewall protection, DMZ port, routing, NAT support, PAT support, LDAP support, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, Intrusion Prevention System (IPS), URL filtering, anti-spam protection, anti-malware protection, Quality of Service (QoS), DHCP server, BitTorrent Client
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 256-bit AES
Authentication Method
RADIUS, LDAP, Active Directory
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB
FCC Class A certified, RoHS, WEEE
Internal power supply
Extended service agreement - replacement - 1 year , Technical support - consulting - 1 year , New releases update - 1 year , Virus definitions update - 1 year , Intrusion definitions update - 1 year
45 °C
Awards
Awards this product has received so far
  • PC PRO Award
    PC PRO Award
    PC PRO Award
