NETGEAR ProSAFE XS728T 28 Port 10GB Smart Switch
28 PORT 10-GIGABIT MANAGED SWITCH
Quicklinx: BS01WS00 Mfr#: XS728T-100NES
Type: 10 Gigabit Ethernet
Ports: 28
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£2,036.89 ex VAT
£2,444.26 inc VAT
The XS728T 10-Gigabit Ethernet Smart Managed Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS728T is a powerful Smart Managed Switch that includes 24 ports of 10-Gigabit connectivity (24 copper with 4 dedicated 10-Gigabit SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS728T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS728T is ideal for is ideal for expanding network capacity, removing performance bottlenecks and/or support of premise expansion needs.
  • Robust security
    With support for RADIUS and TACACS+ authentication methods, alongside TLS 1.0 and TLS 1.2 encryption algorithms, this switch ensures secure network access and data transmission.
  • Efficient performance
    Featuring a switching fabric bandwidth of 560 Gbps and a 3 MB packet buffer, the NETGEAR Smart XS728T facilitates efficient data processing and high-speed connectivity.
  • Advanced networking
    Equipped with Layer 3 Lite advanced switching, IPv4 and IPv6 support, and comprehensive routing protocols including IGMP, MLD, and static routing, this switch is designed for sophisticated network architectures.
  • Enhanced manageability
    Manageable via HTTP, HTTPS, SNMP, and RMON, this device offers versatile remote management options, making network administration more convenient and efficient.
  • Extensive connectivity
    With 24 10GBase-T ports and 4 10 Gigabit SFP+ ports, alongside a dedicated USB 2.0 management port, the switch provides ample connectivity options for diverse networking requirements.
NETGEAR Smart XS728T - switch - 28 ports - smart - rack-mountable
Switch - 28 ports - L3 Lite - smart
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10GBase-T + 4 x 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 560 Gbps
ACL: 164 , Virtual interfaces (VLANs): 512 , IGMP groups: 512 , IPv4 routes: 64 , IPv6 routes: 64 , Priority queues per port: 8 , ARP entries: 1024 , DHCP snooping entries: 1000
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, IPv4 support, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, static routing, CoS, 802.1x authentication, ToS, DSCP support, 4 fans, 3MB packet buffer, cable test, administrator's password, layer 2+ switching
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
AC 120/230 V
44 cm x 31 cm x 4.3 cm
5.04 kg
Latin America, North America, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
TLS 1.0, TLS 1.2
Authentication Method
RADIUS, TACACS+
: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Port transmission speed, power, link/activity, fan
24 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x USB 2.0 management
Internal power supply
AC 120/230 V
173.3 Watt
Rubber feet
Rack Mounting Kit
Included
MTBF
514,977 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, TLS v1.2, TLS v1.0
Software Included
Drivers & Utilities
44 cm
31 cm
4.3 cm
5.04 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BS01 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.09
Ports: 28
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
