The XS716E is the ideal switch for SMBs considering simple and affordable 10-Gigabit Ethernet connectivity into their 10G-capable servers and storage devices. Customers can use Cat6 or Cat7 copper cables with standard RJ45 Ethernet jacks that are already widely used in their current network. Network speeds can improve up to 10x going from traditional Gigabit to 10-Gigabit with minimal network changes and upgrades.
Robust performance
With a switching fabric bandwidth of 320 Gbps and forwarding performance capable of handling 238 Mpps, the NETGEAR Plus XS716E ensures efficient data flow and high-speed connectivity across the network. -
Enhanced connectivity
Equipped with 16 10GBase-T ports and an additional shared 10 Gigabit SFP+ port, this switch offers ample connectivity options for a wide range of devices and network layouts. -
Comprehensive network management
Manageable via HTTP and TFTP, the NETGEAR Plus XS716E allows for easy configuration and monitoring, ensuring your network remains efficient and secure. -
Advanced network features
Features such as VLAN support, Quality of Service (QoS), and port mirroring not only provide enhanced security but also ensure optimal network performance and data prioritization. -
Durable and reliable
With a mean time between failures (MTBF) of 348,257 hours and a comprehensive set of compliance standards, the NETGEAR Plus XS716E is built for long-term reliability and performance.
 - NETGEAR Plus XS716E - switch - 16 ports - Managed - rack-mountable
 - Switch - 16 ports - Managed
- Enclosure Type
 - Rack-mountable
- Subtype
 - 10 Gigabit Ethernet
- Ports
 - 16 x 10GBase-T + 1 x shared 10 Gigabit SFP+
- Performance
 - Switching fabric bandwidth: 320 Gbps , Forwarding performance (64-byte packet size): 238 Mpps
- Capacity
 - Virtual interfaces (VLANs): 128 , IGMP groups: 128 , Priority queues per port: 8
- MAC Address Table Size
 - 16K entries
- Jumbo Frame Support
 - 9KB
- Remote Management Protocol
 - HTTP, TFTP
 - Flow control, full duplex capability, Layer 2 switching, auto-negotiation, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, Multicast Storm Control, firmware upgradable, QoS, Jumbo Frames support, IPv4 support, DHCP client, Energy Efficient Ethernet, 2MB packet buffer, loop prevention, CoS, security lock slot (cable lock sold separately), ToS, DSCP support, 2 fans, cable test
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
- Power
 - AC 120/230 V (50/60 Hz)
 - 44 cm x 20.4 cm x 4.3 cm
 - 3.2 kg
- Localisation
 - Latin America, North America, Europe
 - NETGEAR lifetime warranty
- Enclosure Type
 - Desktop, rack-mountable
- Subtype
- Ports
- Performance
- Capacity
 - 16K entries
 - 9KB
 - HTTP, TFTP
- Status Indicators
 - Port transmission speed, power, link/activity, fan
 - 16 x 10GBase-T RJ-45 , 1 x 10GBase-X SFP+
- Power Device
 - Internal power supply
- Voltage Required
 - 62.7 Watt
- Included Accessories
 - Rubber feet
- Rack Mounting Kit
 - Included
- MTBF
 - 348,257 hours
 - cUL, CCC, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07, KC, ANSI C63.4, EAC, CNS 13438, IEC 60950-1:2005 Second Edition, EN 55024:2010, AS/NZS CISPR22:2009+A1:2010, EN 55022:2010/AC:2011, ICES-003 issue 5 Class A, IEC 60950-1:2005 + A1:2009 + A2:2013, AS/NZS 60950-1:2011, FCC CFR47 Part 15 B Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Localisation
- Software Included
 - ProSAFE Plus Configuration Utility
 - 44 cm
 - 20.4 cm
 - 4.3 cm
 - 3.2 kg
 - Limited warranty - replacement - lifetime - response time: next business day , Product info support - web support - lifetime
 - 0 °C
 - 50 °C
 - 90% (non-condensing)
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 70 °C
