NETGEAR ProSAFE XS716E Switch 16 Ports Managed Desktop, Rack-Mountable
Quicklinx: CHJDWS00 Mfr#: XS716E-100NES
Type: 10 Gigabit Ethernet
Ports: 16
Managed: Yes
£906.49 ex VAT
£1,087.78 inc VAT
The XS716E is the ideal switch for SMBs considering simple and affordable 10-Gigabit Ethernet connectivity into their 10G-capable servers and storage devices. Customers can use Cat6 or Cat7 copper cables with standard RJ45 Ethernet jacks that are already widely used in their current network. Network speeds can improve up to 10x going from traditional Gigabit to 10-Gigabit with minimal network changes and upgrades.
  • Robust performance
    With a switching fabric bandwidth of 320 Gbps and forwarding performance capable of handling 238 Mpps, the NETGEAR Plus XS716E ensures efficient data flow and high-speed connectivity across the network.
  • Enhanced connectivity
    Equipped with 16 10GBase-T ports and an additional shared 10 Gigabit SFP+ port, this switch offers ample connectivity options for a wide range of devices and network layouts.
  • Comprehensive network management
    Manageable via HTTP and TFTP, the NETGEAR Plus XS716E allows for easy configuration and monitoring, ensuring your network remains efficient and secure.
  • Advanced network features
    Features such as VLAN support, Quality of Service (QoS), and port mirroring not only provide enhanced security but also ensure optimal network performance and data prioritization.
  • Durable and reliable
    With a mean time between failures (MTBF) of 348,257 hours and a comprehensive set of compliance standards, the NETGEAR Plus XS716E is built for long-term reliability and performance.
NETGEAR Plus XS716E - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - Managed
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
16 x 10GBase-T + 1 x shared 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 320 Gbps , Forwarding performance (64-byte packet size): 238 Mpps
Virtual interfaces (VLANs): 128 , IGMP groups: 128 , Priority queues per port: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Remote Management Protocol
HTTP, TFTP
Flow control, full duplex capability, Layer 2 switching, auto-negotiation, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, Multicast Storm Control, firmware upgradable, QoS, Jumbo Frames support, IPv4 support, DHCP client, Energy Efficient Ethernet, 2MB packet buffer, loop prevention, CoS, security lock slot (cable lock sold separately), ToS, DSCP support, 2 fans, cable test
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
44 cm x 20.4 cm x 4.3 cm
3.2 kg
Latin America, North America, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
HTTP, TFTP
Status Indicators
Port transmission speed, power, link/activity, fan
16 x 10GBase-T RJ-45 , 1 x 10GBase-X SFP+
Internal power supply
62.7 watt
Rubber feet
Rack Mounting Kit
Included
MTBF
348,257 hours
cUL, CCC, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07, KC, ANSI C63.4, EAC, CNS 13438, IEC 60950-1:2005 Second Edition, EN 55024:2010, AS/NZS CISPR22:2009+A1:2010, EN 55022:2010/AC:2011, ICES-003 issue 5 Class A, IEC 60950-1:2005 + A1:2009 + A2:2013, AS/NZS 60950-1:2011, FCC CFR47 Part 15 B Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Software Included
ProSAFE Plus Configuration Utility
44 cm
20.4 cm
4.3 cm
3.2 kg
Limited warranty - replacement - lifetime - response time: next business day , Product info support - web support - lifetime
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 16
Managed: Yes
Brand: NETGEAR
Price Range Ex VAT: £750 - £1000
