Affordable, wired and wireless (802.11n single band 2.4 GHz) Access Point for small and medium hotels and K-12 dormitories. Sleek, elegant, and compact design allows AP to be deployed in an inconspicuous manner. Can be install in less than 5 minutes with a non- technical personnel and the Access Point is powered by Power Over Ethernet (1Gbps) to reduce cabling cost and time for deployments. WN370 comes with 4 (100Mbsp) Ethernet data ports and one Voice pass through voice port for connectivity of digital phones that requires native access to an in-house PBX system. It has centralized management with WC7600 Wireless Controllers for automatic RF and power tuning with guest access captive portal and comprehensive wireless securities.
Small form factor and inconspicuous appearance
The aesthetically pleasing design of the WN370 allows the access point to blend nicely in the hotel room and school dormitories. WN370 provides wired access directly to the users, where the traditional form factor Access Points are normally installed on the ceiling, away from the access of the users that need wired connectivity. The WN370 is installed with easy attachment to the junction box and appears with a nice decorative appearance. -
Fast installation and PoE powered
The WN370 can be installed easily and less than 5 minutes. The WN370 is powered via Power over Ethernet on the 1 Gbps uplink. Simply connect a Ethernet cable between the WN370 and a PoE enabled switch and the WN370 is up and running. There is no separate power cord needed. -
Flexible and easy deployment
WN370 can be installed easily and does not need sophisticated skills of engineers. WN370s are generally deployed in room, especially effective in areas where deploying the access points in traditional locations (such as ceiling mounted or hallways of dormitories and hotels) are not feasible. Because the WN370 is designed to provide coverage in a specific room, where the RF containment is more well defined, no extensive site survey is required. Finally, because the WN370 comes with four Ethernet ports, users can plug in multiple wired devices without the requirement to pull additional cables from the access point to the wiring closet, thereby saving both time and money to meet the requirements of multiple Ethernet ports per room.
- NETGEAR WN370 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11ac (draft 2.0)
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 9.31 cm x 13.52 cm x 2.59 cm
- 218 g
- NETGEAR lifetime warranty
- 9.31 cm
- 13.52 cm
- 2.59 cm
- 218 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP 1, SNMP 2
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, status, WLAN
- VLAN support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, rogue access point detection, Captive Portal, Auto Healing
- Encryption Algorithm
- WPA, WPA2, WEP
- Authentication Method
- RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0)
Aerial
- Antenna
- Internal
- 1 x 1000Base-T (PoE) - RJ-45 , 4 x 1000Base-T - RJ-45 , 1 x 100Base-TX
- PoE
- Power Device
- External power adapter
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.47 |
