Centralized wireless management for today and future ProSAFE wireless Access Point portfolio, from the entry level single band WNAP210/WNAP320/WN370 to dual band business class WNDAP360/350, and extending up to premium grade 3x3 WNDAP660/620 and supporting future 802.11ac AP’s. The WC7600 is simple to configure with friendly user interface and wizard setup, intuitive to manage with dashboard and comprehensive monitoring statistics, and cost effective. The WC7600 is developed specifically for small and medium enterprise, K-12 education, and small and mid-size healthcare looking to deploy a fully managed and redundant wireless solution. With simplicity and ease of use in mind, the WC7600 is purpose built to bridge the gap between the basic standalone Access Point and the complex and difficult to manage high end wireless controllers. The WC7600 is ideal for IT challenged customers looking for a solution that automatically configure and tune the wireless network for optimal performance. The WC7600 comes fully equipped with enterprise grade features such as comprehensive wireless security (WPA, WPA2, Radius, LDAP, Rogue AP protection), guest access, and full networking functionality from embedded DHCP server, VLAN on wired and wireless networks, to full Quality of Service for different class of users. The WC7600 is a fully redundant hardware (redundant fans, hot swappable power supply).
- NETGEAR WC7600 Premium Wireless Controller - network management device
- Network management device
- Form Factor
- External - 1U
- Localisation
- Worldwide (excluding China)
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet
- Capacity
- Manageable access points: 50 , Maximum number of access points (per cluster): 150 , BSSIDs: 144 , Concurrent stations per cluster: 6000 , Concurrent stations: 2000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
- Power
- AC 100/230 V
- Power Redundancy
- 44 cm x 43 cm x 4.3 cm
- 7.57 kg
- NETGEAR lifetime warranty
- Height (Rack Units)
- 1U
- 44 cm
- 43 cm
- 4.3 cm
- 7.57 kg
- Localisation
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
- Routing Protocol
- CIDR
- Remote Management Protocol
- SNMP 1, RMON, Telnet, SNMP 2c, HTTP, TFTP, SSH
- Capacity
- Status Indicators
- Power, status, fan
- Auto-sensing per device, auto-negotiation, load balancing, LDAP support, VLAN support, Syslog support, stackable, IPv6 support, SNTP support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Access Control List (ACL) support, RADIUS support, roaming function, DHCP server, IPv4 support, rogue access point detection, tagged VLAN, Captive Portal
- Encryption Algorithm
- DES, Triple DES, IKE, TKIP, WPA-PSK, AES-CCMP, AES-CCM, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, AES-CBC, 128-bit SSL, 1024-bit RSA, 2048-bit RSA, TLS 1.1, WEP
- Authentication Method
- X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
- 2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
- MTBF
- 664,072 hours
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 100/230 V
- 82.3 Watt
- Power Provided
- 165 Watt
- Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days
- 0 °C
- 45 °C
- 10 - 90%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
