NETGEAR ProSafe WC7500
Quicklinx: C22DWS00 Mfr#: WC7500-10000S
Type: Wireless network management device
Connectivity: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet, PPP
Compatibility: PC
£729.90 ex VAT
£875.88 inc VAT
Manage thousands of users with one smart and easy controller.
Exceptional ease-of-use. Best-in-class performance. A full-featured, reliable Wireless LAN architecture. In short, the WC7520 is the smart, easy choice to meet the demands of mid-size organizations with thousands of users.
Reliable, Secure and Scalable Wireless Controller for Mid-sized Businesses, Schools and Hospitals
The NETGEAR ProSAFE® Wireless Controller WC7520 offers a high-performance, fully-featured, yet extremely affordable, Wireless LAN architecture to meet the demands of medium-sized businesses, schools, and hospitals with thousands of users.
Performance
  • Seamless L2 and L3 fast roaming provide support for latency-sensitive applications such as video, audio and voice over wireless
  • Dynamic RF Management: Automatic controls of AP transmit power and channel allocations ensure coverage by minimizing interferences
  • Self-healing Wireless: Automatic WLAN healing after loss of AP or due to RF interferences adapts the power and channel of the other APs around the area
  • Load balancing and rate limiting ensure fair bandwidth allocation among all clients for robust wireless connectivity
  • Dynamic load balancing of clients across APs is provided based on number of clients per AP, or based on signal strength threshold/data rate threshold of clients per AP
Scalability
  • The scalable WC7520 Controller enables businesses to grow their wireless network as needed with a dramatic return on investment: WC7520 scales up to 50 access points (AP) - and up to 150 access points (AP) with stacking
  • Support of controller redundancy to maximize reliability
Business Value
  • Customer floor maps: Heat maps by wireless band, wireless channel and signal strength allow real-time reporting of the wireless network status
  • Redundancy for always-on reliability and peace of mind: N+1 redundancy with failover (one cold redundant Controller for 1, 2 or 3 production Controllers)
  • Built to last, the WC7520 Controller is backed by a Lifetime Warranty
Ease of Use
  • Con?gure the MAC address ?lters, make SSID changes, and change the password for all access points—all from the single WC7520 interface
  • Triangulation: Administrators can easily locate known APs, rogue APs, and associated clients on the heat map
  • Wireless bundles (for single and dual band APs) for ease of ordering
  • Robust security
    Equipped with a comprehensive suite of encryption algorithms including AES, WPA2-Enterprise, and WPA2-PSK, this device ensures a secure network environment, safeguarding sensitive data against unauthorized access.
  • High capacity management
    Designed to manage up to 15 manageable access points and support 2000 concurrent stations, making it ideal for medium to large-scale deployments.
  • Advanced connectivity
    Features 4 1000Base-T RJ-45 connectors, a console port, and a USB 2.0 port, offering versatile connectivity options for a wide range of network configurations.
  • Comprehensive environmental adaptability
    Operates efficiently across a wide range of humidity (10 - 90%) and temperatures (0°C to 45°C), ensuring reliable performance in various operating conditions.
  • Efficient network management
    Supports numerous remote management protocols including SNMP, HTTP, and SSH, facilitating easy and effective network management and monitoring.
NETGEAR WC7500 - wireless network management device
External - 1U
Worldwide (excluding China)
Ethernet, Fast Ethernet, Gigabit Ethernet, PPP
Manageable access points: 10 , Maximum number of access points: 15 , BSSIDs: 144 , Concurrent stations: 2000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
AC 100/230 V
44 cm x 26.2 cm x 4.3 cm
3.6 kg
NETGEAR lifetime warranty
NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740
Height (Rack Units)
1U
44 cm
26.2 cm
4.3 cm
3.6 kg
External
Wired
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
Routing Protocol
CIDR
Remote Management Protocol
SNMP 1, SNMP 2, RMON, Telnet, HTTP, TFTP, SSH
Auto-sensing per device, DHCP support, auto-negotiation, load balancing, VLAN support, IPv6 support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), IPv4 support, rogue access point detection, Management Information Base (MIB), rate limit
Encryption Algorithm
DES, Triple DES, RC4, AES, IKE, SSL, TKIP, WPA, PKI, AES-CCMP, AES-CCM, WPA2-PSK, WPA2-Enterprise, AES-CBC, TLS 1.1, WEP
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
4 x 1000Base-T - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
MTBF
664,072 hours
AC 100/230 V
13 Watt
Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days , Technical support - lifetime
45 °C
10 - 90%
NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740
C22D C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
C22D C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.76
Connectivity: Wired
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: PPP
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: £500 - £750
