The WB7530 Business Controller Bundle is the perfect offer for businesses entering the 11ac era.
The package contains one (1) WC7500 Business Wireless Controller, five (5) WAC730 802.11ac Wireless Access Points.
The controller supports up to 10 APs (15 with additional license).
Manage thousands of users with one smart and easy controller
Exceptional ease-of-use. Best-in-class performance. A full-featured, reliable Wireless LAN architecture. In short, the WC7530 is the smart, easy choice to meet the demands of mid-size organizations with thousands of users.
Reliable, Secure and Scalable Wireless Controller for Mid-sized Businesses, Schools and Hospitals
The NETGEAR ProSAFEĀ® Wireless Controller WC7520 offers a high-performance, fully-featured, yet extremely affordable, Wireless LAN architecture to meet the demands of medium-sized businesses, schools, and hospitals with thousands of users.
Performance
- Seamless L2 and L3 fast roaming provide support for latency-sensitive applications such as video, audio and voice over wireless
- Dynamic RF Management: Automatic controls of AP transmit power and channel allocations ensure coverage by minimizing interferences
- Self-healing Wireless: Automatic WLAN healing after loss of AP or due to RF interferences adapts the power and channel of the other APs around the area
- Load balancing and rate limiting ensure fair bandwidth allocation among all clients for robust wireless connectivity
- Dynamic load balancing of clients across APs is provided based on number of clients per AP, or based on signal strength threshold/data rate threshold of clients per AP
Scalability
- The scalable WC7520 Controller enables businesses to grow their wireless network as needed with a dramatic return on investment: WC7520 scales up to 50 access points (AP) - and up to 150 access points (AP) with stacking
- Support of controller redundancy to maximize reliability
Business Value
- Customer floor maps: Heat maps by wireless band, wireless channel and signal strength allow real-time reporting of the wireless network status
- Redundancy for always-on reliability and peace of mind: N+1 redundancy with failover (one cold redundant Controller for 1, 2 or 3 production Controllers)
- Built to last, the WC7520 Controller is backed by a Lifetime Warranty
Ease of Use
- Configure the MAC address ?lters, make SSID changes, and change the password for all access points?all from the single WC7520 interface
- Triangulation: Administrators can easily locate known APs, rogue APs, and associated clients on the heat map
- Wireless bundles (for single and dual band APs) for ease of ordering
Robust security
Equipped with a comprehensive suite of encryption algorithms including AES, WPA2-Enterprise, and WPA2-PSK, this bundle ensures a secure network environment. Advanced authentication methods like Active Directory, LDAP, and RADIUS further fortify network integrity. -
High capacity management
Designed to manage up to 15 manageable access points and support 2000 concurrent stations, making it ideal for medium to large-scale deployments. With the ability to detect up to 512 rogue access points, network security is enhanced. -
Versatile connectivity
Features multiple interface options including 4 x 1000Base-T RJ-45 connectors for Gigabit Ethernet, a DB-9 console port, and a Type-A USB 2.0 port, providing flexible connectivity solutions. -
Comprehensive networking features
Supports a wide range of networking protocols and features such as IPv4/IPv6 support, Quality of Service (QoS), VLAN, and Wi-Fi Multimedia (WMM) support, ensuring a versatile and efficient network. -
Durable and reliable
With an MTBF of 664,072 hours and designed to operate within a wide range of temperatures and humidity, this wireless controller bundle is built for long-term reliability and performance.
- NETGEAR WB7500 Wireless Controller Bundle - wireless network management device - with 5 x NETGEAR ProSafe Business 3 x 3 Dual Band Wireless-AC Access Point WAC730
- Wireless network management device
- Form Factor
- External - 1U
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, PPP
- Capacity
- Manageable access points: 10 , Maximum number of access points: 15 , BSSIDs: 144 , Concurrent stations: 2000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
- Power
- AC 100/230 V
- 44 cm x 26.2 cm x 4.3 cm
- 3.6 kg
- Bundled with
- 5 x NETGEAR ProSafe Business 3 x 3 Dual Band Wireless-AC Access Point WAC730
- Height (Rack Units)
- 1U
- 44 cm
- 26.2 cm
- 4.3 cm
- 3.6 kg
- Bundled with
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
- Routing Protocol
- CIDR
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, Telnet, HTTP, TFTP, SSH
- Capacity
- Auto-sensing per device, DHCP support, auto-negotiation, load balancing, VLAN support, IPv6 support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), IPv4 support, rogue access point detection, Management Information Base (MIB), rate limit
- Encryption Algorithm
- DES, Triple DES, RC4, AES, IKE, SSL, TKIP, WPA, PKI, AES-CCMP, AES-CCM, WPA2-PSK, WPA2-Enterprise, AES-CBC, TLS 1.1, WEP
- Authentication Method
- RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
- 4 x 1000Base-T - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
- MTBF
- 664,072 hours
- Voltage Required
- AC 100/230 V
- 13 Watt
- 0 °C
- 45 °C
- 10 - 90%
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.09 |
