NetGear ProSAFE WAC720  2 x 2 Dual Band Wireless AC Access Point
LIFETIME WARRANTY WITH NEXT BUSINESS DAY DELIVERY!
Quicklinx: BV0QWS00 Mfr#: WAC720-10000S
  • IEEE 802.11n
The NETGEAR WAC720 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.2 Gbps (300 Mbps for 2.4GHz and 867 Mbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC720 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
  • Enhanced security
    With a suite of features including Extensible Authentication Protocol (EAP), RADIUS, and WPA2 encryption, this access point ensures a secure network environment, safeguarding sensitive data from unauthorized access.
  • Robust connectivity
    Equipped with Dual Band Wireless-AC technology, the device offers aggregate throughput of 1.2 Gbps, with up to 300 Mbps on the 2.4 GHz band and 867 Mbps on the 5 GHz band, ensuring high-speed Internet access for multiple devices.
  • Versatile networking
    Supports a wide range of networking protocols and features such as VLAN support, VPN support, and Multiple SSID support, providing flexible configuration options to meet various business networking needs.
  • Comprehensive management
    Remote management protocols including SNMP, CLI, and HTTP, allow for easy setup, monitoring, and maintenance of the network infrastructure from anywhere.
  • Efficient installation
    Power over Ethernet (PoE) capability simplifies deployment by eliminating the need for a separate power supply, enabling flexible placement and reducing installation costs.
NETGEAR Business 2 x 2 Dual Band Wireless-AC Access Point WAC720 - radio access point - Wi-Fi 5
Radio access point
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE
19.7 cm x 19.7 cm x 4 cm
726 g
NETGEAR lifetime warranty
Radio access point
19.7 cm
19.7 cm
4 cm
726 g
External
Wired
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, LAN, wireless, link/activity
VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, 802.1x authentication, Transmit Power Control (TPC)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
External detachable and internal
1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 2 x aerial - RP-SMA
1 x network cable
PoE
Limited warranty - lifetime
