NetGear Prosafe VPN Client Software 5 User
Customer rating: 1.0* (Write a review)
Quicklinx: 3K7LWS00 Mfr#: VPN05L
Today's distributed mobile workforce requires secure, remote access to corporate network resources. Network security administrators need a VPN client solution that is simple to deploy, manageable and completely secure. NETGEAR's ProSafe VPN Client software delivers the ideal solution, with robust encryption and broad support across multiple connection types and Microsoft Windows operating platforms. The ProSafe VPN client provides easy setup and seamless compatibility with the full line of NETGEAR VPN/Firewall routers as well as compatibility with IPSec VPN solutions from other leading manufacturers. With the NETGEAR ProSafe VPN client, NETGEAR extends its line of cost-effective security offerings, providing a single-vendor solution for growing businesses.
Supports a wide range of security protocols and authentication methods, including Advanced Encryption Standard (AES), Data Encryption Standard (DES), 3DES, Message-Digest Algorithm (MD5) and Secure Hash Algorithm (SHA-1). Also supports Public-Key Infrastructure (PKI) and Internet Key Exchange (IKE - Main and Aggressive modes), plus a wide range of Smart Cards and certificate authorities.
Provides protected access to corporate resources via wireless, broadband, and dial-up connections. Supports NETGEAR VPN/Firewall routers, including the FVS318, FVL328, FVM318, and FWAG114, as well as many other IPSec-compliant VPN devices. Enables client-initiated VPNs from Windows 98, Me, XP, 2000, and Windows NT-based PCs.
NETGEAR provides pre-configuration files for NETGEAR ProSafe VPN/Firewall routers to minimize setup and support costs of the ProSafe VPN client software. NETGEAR's ProSafe VPN client allows you to configure security policies and manage certificates through its Windows-based graphical user interface, and to create and distribute customized installations for easy setup of end users. The ProSafe VPN client includes several modules that make it easy to configure and diagnose connection problems:
Includes Network Address Translation (NAT) traversal support for VPN clients behind devices that support VPN pass-through mode. Supports multiple configurations, including split tunneling, block tunneling, and central tunneling. Provides redundant gateway capability and keepalives for increased reliability.
ProSafe VPN Client - box pack - 5 users
Box pack
Category
Security applications - VPN software
Licence Qty
5 users
Platform
Windows
Distribution Media
CD-ROM
Product info support
NETGEAR FVM318, FVS318, FVS328, FWAG114
Category
Box pack
Platform
Windows
Distribution Media
CD-ROM
Triple DES, DES, MD5, SHA-1, Diffie-Hellman, AES-128, AES-192, AES-256, PKCS#12, X.509, PKCS#7, PKCS#10
Licencing
Licence Qty
5 users
Supported OS
Microsoft Windows 98, Microsoft Windows NT 4.0, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP
Hardware Requirements
Microsoft Windows 98 - RAM 16 MB , Microsoft Windows NT 4.0 - RAM 32 MB , Microsoft Windows 2000 / XP - RAM 64 MB , Microsoft Windows Millennium Edition - RAM 64 MB
E-mail consulting
Customer reviews
Write a review for the NetGear Prosafe VPN Client Software 5 User here!
Very poor quality software
Reviewed by Anonymous Review Posted 09/01/2009
I purchased this along with two Netgear FVS318 routers to enable secure VPN client connections to two of our offices and was VERY disappointed with the product.
The latest version was not supplied and an upgrade to the latest version was not available without contacting Netgear support.
Uninstalling the old version was a complete nightmare and installation of the latest version was also problematic.
Once installed, I have still (after several days effort) not been able to connect the client to the Netgear router. The interface is not user friendly and the documentation on the CD does not match either the Netgear website or information supplied by support.
I am on the verge of sending the software and routers back because they are not fit for purpose. So my advice is...avoid Netgear at all costs.
Regards
John
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
