NetGear ProSafe VPN Client Software - 1 User
Customer rating: 3.0* (Write a review)
Quicklinx: 3K6TWS00 Mfr#: VPN01L
Today's distributed mobile workforce requires secure, remote access to corporate network resources. Network security administrators need a VPN client solution that is simple to deploy, manageable and completely secure. NETGEAR's ProSafe VPN Client software delivers the ideal solution, with robust encryption and broad support across multiple connection types and Microsoft Windows operating platforms. The ProSafe VPN client provides easy setup and seamless compatibility with the full line of NETGEAR VPN/Firewall routers as well as compatibility with IPSec VPN solutions from other leading manufacturers. With the NETGEAR ProSafe VPN client, NETGEAR extends its line of cost-effective security offerings, providing a single-vendor solution for growing businesses.
Supports a wide range of security protocols and authentication methods, including Advanced Encryption Standard (AES), Data Encryption Standard (DES), 3DES, Message-Digest Algorithm (MD5) and Secure Hash Algorithm (SHA-1). Also supports Public-Key Infrastructure (PKI) and Internet Key Exchange (IKE - Main and Aggressive modes), plus a wide range of Smart Cards and certificate authorities.
Provides protected access to corporate resources via wireless, broadband, and dial-up connections. Supports NETGEAR VPN/Firewall routers, including the FVS318, FVL328, FVM318, and FWAG114, as well as many other IPSec-compliant VPN devices. Enables client-initiated VPNs from Windows 98, Me, XP, 2000, and Windows NT-based PCs.
NETGEAR provides pre-configuration files for NETGEAR ProSafe VPN/Firewall routers to minimize setup and support costs of the ProSafe VPN client software. NETGEAR's ProSafe VPN client allows you to configure security policies and manage certificates through its Windows-based graphical user interface, and to create and distribute customized installations for easy setup of end users. The ProSafe VPN client includes several modules that make it easy to configure and diagnose connection problems:
Includes Network Address Translation (NAT) traversal support for VPN clients behind devices that support VPN pass-through mode. Supports multiple configurations, including split tunneling, block tunneling, and central tunneling. Provides redundant gateway capability and keepalives for increased reliability.
ProSafe VPN Client - box pack - 1 user
Box pack
Category
Security applications - VPN software
Licence Qty
1 user
Platform
Windows
Distribution Media
CD-ROM
NETGEAR FVL328, FVM318, FVS318, FWAG114, FWG114P, MR814, RP614, WGR614, WGT624, WMB111
Category
Box pack
Platform
Windows
Distribution Media
CD-ROM
56-bit encryption, 168-bit encryption, Triple DES, DES, MD5, SHA-1, AES-128, AES-192, AES-256, PKCS#12, X.509, PKCS#7, PKCS#10
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows 98, Microsoft Windows NT 4.0, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP, Microsoft Windows Vista
Hardware Requirements
Microsoft Windows 98 - RAM 16 MB , Microsoft Windows 2000 / NT4.0 - RAM 32 MB , Microsoft Windows Vista / XP - RAM 64 MB , Microsoft Windows Millennium Edition - RAM 32 MB
Customer reviews
Write a review for the NetGear ProSafe VPN Client Software - 1 User here!
Does exactly what it should do
Reviewed by Anonymous Review Posted 30/09/2009
Got my first license for this software with a netgear router and was able to establish good, reliable connections to both netgear and other manufacturers hardware without issue.
Have since purchased further licenses to get other users accessing remotely and this client software has been successful where other software has failed.
  • Overall 4*
  • Ease of use 4*
  • Value for money 2*
It does not do what it says on the box!
Reviewed by Anonymous Review Posted 12/09/2008
I bought this software hoping to establish VPN with my Netgear Router DG834. I followed all instructions in the manual and was unable to establish connection. I then looked up all possible troubleshooting articles on the web and tried various settings but all unsuccessfully. This product is a sham and complete waste of valuable time. Do not fall in the same trap buying it, thinking that it can work well with Netgear products. In fact, it can not work well with any brand. I am so disappointed!
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
