NETGEAR ProSafe Plus XS708Ev2 Switch 8 Ports Managed Desktop, Rack-Mountable
Quicklinx: CHJBWS00 Mfr#: XS708E-200NES
Type: 10 Gigabit Ethernet
Ports: 8
Managed: Yes
£424.89 ex VAT
£509.86 inc VAT
The 2nd Generation NETGEAR ProSAFE XS708Ev2 is a powerful Web Managed (Plus) Switch that includes 8 ports of 10-Gigabit connectivity (8 copper with 1 shared combo copper/SFP+ Fiber port) for business class networks. NETGEAR's 10-Gigabit Web Managed (Plus) Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. They can be used at the "center of a small business network" or as an aggregation / access switch in a larger organization including workgroup access.
The XS708Ev2 provides configurable L2 network features allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It delivers unprecedented non-blocking 10-Gigabit bandwidth at an affordable cost, and is plug-and-play out of the box, or can be easily configured for advanced features via the Web browser-based management GUI. The XS708Ev2 is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
  • 10GBASE-T connections
    Support low-latency, line-rate 10G Copper "BASE-T" technology with backward compatibility to Gigabit Ethernet and Fast Ethernet. Cost-effectively migrate current network to 10G capacity by utilizing the existing Cat 6 RJ45 short connections (up to 45 m) and Cat 6a/Cat 7 connections up to 100 m.
  • 10GBASE-X SFP+ ports
    Providing flexibility to uplink to 10G-capable core or aggregation switches that support fiber links. Backward compatible to Gigabit fiber. Support copper or fiber modules.
NETGEAR Plus XS708Ev2 - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
8 x 10 Gigabit Ethernet + 1 x combo SFP+
Performance
Switching fabric bandwidth: 160 Gbps , Forwarding performance (64-byte packet size): 119 Mfps
VLANs supported: 128 , IGMP groups: 128 , Jumbo frame size: up to 9 KB , LAG groups: 4 , Concurrent tunneled ports:
MAC Address Table Size
16K entries
Jumbo Frame Support
Remote Management Protocol
HTTP
Flow control, Layer 2 switching, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, QoS, Jumbo Frames support, IPv4 support, DHCP client, Energy Efficient Ethernet, loop prevention, security lock slot (cable lock sold separately), ToS, DSCP support, 2 fans, cable test, Link Aggregation, rate limit
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
AC 100/230 V (50/60 Hz)
44 cm x 20.4 cm x 4.3 cm
2.8 kg
Microsoft Windows Vista / XP / 7 / 8
Latin America, North America, Europe
ProSAFE lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
HTTP
Status Indicators
Port status, power, link/activity, fan, link/speed
8 x 10GBase-T RJ-45 , 1 x SFP+
Internal power supply
43.4 Watt
Rubber feet
Rack Mounting Kit
Included
MTBF
397,731 hours
C-Tick, CISPR 22 Class A, cUL, EN55022 Class A, UL 60950, CB, CCC, FCC Part 15 A, KC, VCCI Class A
Software Included
Drivers & Utilities, ProSAFE Plus Configuration Utility
44 cm
20.4 cm
4.3 cm
2.8 kg
Technical support - phone consulting - 90 days , Technical support - web support - lifetime , Limited warranty - replacement - lifetime - response time: next business day
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Ports: 8
Managed: Yes
Brand: NETGEAR
