The 2nd Generation NETGEAR ProSAFE XS708Ev2 is a powerful Web Managed (Plus) Switch that includes 8 ports of 10-Gigabit connectivity (8 copper with 1 shared combo copper/SFP+ Fiber port) for business class networks. NETGEAR's 10-Gigabit Web Managed (Plus) Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. They can be used at the "center of a small business network" or as an aggregation / access switch in a larger organization including workgroup access.
The XS708Ev2 provides configurable L2 network features allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It delivers unprecedented non-blocking 10-Gigabit bandwidth at an affordable cost, and is plug-and-play out of the box, or can be easily configured for advanced features via the Web browser-based management GUI. The XS708Ev2 is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
10GBASE-T connections
Support low-latency, line-rate 10G Copper "BASE-T" technology with backward compatibility to Gigabit Ethernet and Fast Ethernet. Cost-effectively migrate current network to 10G capacity by utilizing the existing Cat 6 RJ45 short connections (up to 45 m) and Cat 6a/Cat 7 connections up to 100 m. -
10GBASE-X SFP+ ports
Providing flexibility to uplink to 10G-capable core or aggregation switches that support fiber links. Backward compatible to Gigabit fiber. Support copper or fiber modules.
- NETGEAR Plus XS708Ev2 - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 8 x 10 Gigabit Ethernet + 1 x combo SFP+
- Performance
- Switching fabric bandwidth: 160 Gbps , Forwarding performance (64-byte packet size): 119 Mfps
- Capacity
- VLANs supported: 128 , IGMP groups: 128 , Jumbo frame size: up to 9 KB , LAG groups: 4 , Concurrent tunneled ports:
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- Remote Management Protocol
- HTTP
- Flow control, Layer 2 switching, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, QoS, Jumbo Frames support, IPv4 support, DHCP client, Energy Efficient Ethernet, loop prevention, security lock slot (cable lock sold separately), ToS, DSCP support, 2 fans, cable test, Link Aggregation, rate limit
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
- Power
- AC 100/230 V (50/60 Hz)
- 44 cm x 20.4 cm x 4.3 cm
- 2.8 kg
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- Localisation
- Latin America, North America, Europe
- ProSAFE lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 16K entries
- HTTP
- Status Indicators
- Port status, power, link/activity, fan, link/speed
- 8 x 10GBase-T RJ-45 , 1 x SFP+
- Power Device
- Internal power supply
- Voltage Required
- 43.4 watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 397,731 hours
- C-Tick, CISPR 22 Class A, cUL, EN55022 Class A, UL 60950, CB, CCC, FCC Part 15 A, KC, VCCI Class A
- Localisation
- Software Included
- Drivers & Utilities, ProSAFE Plus Configuration Utility
- OS Required
- 44 cm
- 20.4 cm
- 4.3 cm
- 2.8 kg
- Technical support - phone consulting - 90 days , Technical support - web support - lifetime , Limited warranty - replacement - lifetime - response time: next business day
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
