NetGear ProSAFE M6100-44GF3 Starter Kit Switch
Quicklinx: BYMWWS00 Mfr#: XCM8903SF-10000S
Type: Gigabit Ethernet
Ports: 44
Managed: Yes
£2,750.53 ex VAT
£3,300.63 inc VAT
The ProSAFE M6100 Switch Series consists of Gigabit access layer and 10 Gigabit distribution layer switches in NETGEAR modular chassis switch product line. The M6100 switch series offers high-quality, high-density chassis alternative to stackable switches in campus LAN and midsize organizations demanding networks. With more than 1.4 Tbps switching and routing capacity, passive backplane, management and fabric nonstop forwarding redundancy, the M6100 series delivers world-class resiliency and scalability. Ultimately, operating software and system management features take the complexity out of delivering L2/L3/L4 rich services for enterprise edge and SMB core deployments.
  • Robust security
    Equipped with AES, SSL 3.0, and TLS 1.0 encryption algorithms alongside RADIUS, SSH, and TACACS+ authentication methods, this switch ensures secure network access and data transmission.
  • High capacity networking
    Supports up to 4000 VLANs, 8000 ARP entries, and advanced routing protocols including OSPF, BGP, and RIP, making it ideal for complex network infrastructures.
  • Efficient management
    Features comprehensive remote management protocols such as SNMP, RMON, CLI, and more, allowing for efficient network monitoring and management.
  • Enhanced connectivity
    Offers 44 ports of 10/100/1000 Ethernet, 2 ports of 10Gb Ethernet, and 2 ports of 10 Gigabit SFP+ for versatile and high-speed network connections.
  • Optimized for performance
    With features like Quality of Service (QoS), VLAN support, and advanced switching capabilities, this switch is designed to optimize network performance and reliability.
NETGEAR M6100-44GF3 - Starter Kit - switch - 44 ports - Managed - rack-mountable
Switch - 44 ports - L4 - Managed
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Ports
40 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10 Gigabit SFP+
Virtual interfaces (VLANs): 4000 , Static routes: 512 , RIP routes: 512 , OSPF routes: 12000 , BGP routes: 12000 , ARP entries: 8000 , IPv4 forwarding table entries: 1536 , IPv6 forwarding table entries: 512
MAC Address Table Size
32000 entries
Jumbo Frame Support
12KB
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, BGP, IGMPv2, DVMRP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPF for IPv6, OSPFv3, static IPv4 routing, static IPv6 routing, ECMP, policy-based routing (PBR), MLDv2, PIM-SMv6, BGP for IPv6, PIM-DMv6
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, WFQ, WRED, sFlow, STP support, RSTP support, PVST, MSTP support, DCBX support, priority-based flow control, DHCP snooping, TFTP support, ACL support, QoS, DHCP server, MLD snooping, DAI, STP Root Guard, UDLD, DWRR, LLDP support, DHCP relay, RSPAN, PVRST, DHCP client, Energy Efficient Ethernet, MIB, dual firmware images, MVRP, SPQ, CoS, tagged VLAN, GARP, IGMP proxy, ToS, DSCP support, MLD proxy, FCoE Initialization Protocol (FIP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz
Power Redundancy
Optional
43.2 cm x 44.16 cm x 17.59 cm
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Ports
32000 entries
Jumbo Frame Support
12KB
Routing Protocol
Encryption Algorithm
AES, TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1: 800 MHz
RAM
1 GB
Flash Memory
64 MB
Status Indicators
Port transmission speed, power, status, link/activity, supervisor
40 x 1000Base-T RJ-45 , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial RJ-45 , 1 x management (mini-USB) , 1 x USB Type A
Expansion Slots
3 (total) / 2 (free) x Expansion Slot
Installed Modules Qty (Max)
1 (installed) / 3 (max)
Installed Qty
1
Max Supported Qty
4
Power Redundancy
Optional
Power Redundancy Scheme
N+1
Power Provided
1000 Watt
80 PLUS Certification
80 PLUS
Redundant Power System (RPS) connector
Fan tray
Rack Mounting Kit
Included
CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A
43.2 cm
44.16 cm
17.59 cm
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting - 90 days , Technical support - web support - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
BYMW C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BYMW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.69
Ports: 44
Managed: Yes
Brand: NETGEAR
Price Range Ex VAT: £1500+
