The ProSAFE M6100 Switch Series consists of Gigabit access layer and 10 Gigabit distribution layer switches in NETGEAR modular chassis switch product line. The M6100 switch series offers high-quality, high-density chassis alternative to stackable switches in campus LAN and midsize organizations demanding networks. With more than 1.4 Tbps switching and routing capacity, passive backplane, management and fabric nonstop forwarding redundancy, the M6100 series delivers world-class resiliency and scalability. Ultimately, operating software and system management features take the complexity out of delivering L2/L3/L4 rich services for enterprise edge and SMB core deployments.
Robust security
Equipped with AES, SSL 3.0, and TLS 1.0 encryption algorithms alongside RADIUS, SSH, and TACACS+ authentication methods, this switch ensures secure network access and data transmission. -
High capacity networking
Supports up to 4000 VLANs, 8000 ARP entries, and advanced routing protocols including OSPF, BGP, and RIP, making it ideal for complex network infrastructures. -
Efficient management
Features comprehensive remote management protocols such as SNMP, RMON, CLI, and more, allowing for efficient network monitoring and management. -
Enhanced connectivity
Offers 44 ports of 10/100/1000 Ethernet, 2 ports of 10Gb Ethernet, and 2 ports of 10 Gigabit SFP+ for versatile and high-speed network connections. -
Optimized for performance
With features like Quality of Service (QoS), VLAN support, and advanced switching capabilities, this switch is designed to optimize network performance and reliability.
- NETGEAR M6100-44GF3 - Starter Kit - switch - 44 ports - Managed - rack-mountable
- Switch - 44 ports - L4 - Managed
- Enclosure Type
- Rack-mountable 4U
- Subtype
- Gigabit Ethernet
- Ports
- 40 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10 Gigabit SFP+
- Capacity
- Virtual interfaces (VLANs): 4000 , Static routes: 512 , RIP routes: 512 , OSPF routes: 12000 , BGP routes: 12000 , ARP entries: 8000 , IPv4 forwarding table entries: 1536 , IPv6 forwarding table entries: 512
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 12KB
- Routing Protocol
- OSPF, BGP-4, RIP-1, RIP-2, BGP, IGMPv2, DVMRP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPF for IPv6, OSPFv3, static IPv4 routing, static IPv6 routing, ECMP, policy-based routing (PBR), MLDv2, PIM-SMv6, BGP for IPv6, PIM-DMv6
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
- BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, WFQ, WRED, sFlow, STP support, RSTP support, PVST, MSTP support, DCBX support, priority-based flow control, DHCP snooping, TFTP support, ACL support, QoS, DHCP server, MLD snooping, DAI, STP Root Guard, UDLD, DWRR, LLDP support, DHCP relay, RSPAN, PVRST, DHCP client, Energy Efficient Ethernet, MIB, dual firmware images, MVRP, SPQ, CoS, tagged VLAN, GARP, IGMP proxy, ToS, DSCP support, MLD proxy, FIP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.2 cm x 44.16 cm x 17.59 cm
- NETGEAR lifetime warranty
- Enclosure Type
- Rack-mountable 4U
- Subtype
- Gigabit Ethernet
- Ports
- Capacity
- 32000 entries
- 12KB
- Routing Protocol
- Encryption Algorithm
- AES, TLS 1.0, SSL 3.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- 1: 800 MHz
- RAM
- 1 GB
- Flash Memory
- 64 MB
- Status Indicators
- Port transmission speed, power, status, link/activity, supervisor
- 40 x 1000Base-T RJ-45 , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial RJ-45 , 1 x management (mini-USB) , 1 x USB Type A
- Expansion Slots
- 3 (total) / 2 (free) x Expansion Slot
- Installed Modules Qty (Max)
- 1 (installed) / 3 (max)
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 4
- Power Redundancy
- Optional
- Power Redundancy Scheme
- N+1
- Power Provided
- 1000 watt
- Voltage Required
- 80 PLUS Certification
- 80 PLUS
- Redundant Power System (RPS) connector
- Included Accessories
- Fan tray
- Rack Mounting Kit
- Included
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A
- 43.2 cm
- 44.16 cm
- 17.59 cm
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting - 90 days , Technical support - web support - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
