NETGEAR ProSAFE M4300-48X Switch 48 Ports Managed Rack-Mountable
Quicklinx: CHJGWS00 Mfr#: XSM4348CS-100NES
Type: 10 Gigabit Ethernet
Ports: 48
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
12 In Stock
£5,808.47 ex VAT
£6,970.16 inc VAT
The NETGEAR M4300 Stackable Switch Series delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series, enabling spine and leaf line-rate stacking topologies. Non-stop forwarding (NSF) virtual chassis architectures provide advanced High Availability (HA) with hitless failover across the stack. Dual redundant, modular power supplies equipping full width models contribute to business continuity management. Layer 3 feature set includes static, dynamic and policy-based routing – as standard. Perfect for wireless access, unified communications and IP video, the NETGEAR M4300 Switch Series is also ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
  • Robust performance
    With a switching capacity of 960 Gbps and throughput of 714 Mpps, the NETGEAR M4300-48X ensures efficient data handling and high-speed connectivity. Its low latency across various packet sizes enhances real-time application performance.
  • Advanced networking
    Equipped with Layer 3 switching capabilities and support for multiple routing protocols including OSPF, RIP, and VRRP, this switch is designed for complex network architectures. Features like Access Control List (ACL) support and Quality of Service (QoS) enable sophisticated network traffic management.
  • High capacity
    The switch supports up to 4093 VLANs, making it suitable for large-scale deployments. With a MAC Address Table Size of 128K entries, it efficiently manages network traffic and devices.
  • Secure and manageable
    Featuring advanced security protocols including RADIUS and TACACS+ authentication, the NETGEAR M4300-48X ensures network integrity. Manageable via CLI, HTTPS, and SNMP, it offers flexible administration options.
  • Energy efficient
    Compliant with IEEE 802.3az, the switch optimizes power usage, reducing operational costs without compromising performance. Its internal power supply with a maximum consumption of 237.2 watts further underscores its efficiency.
NETGEAR M4300-48X - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit Ethernet + 4 x shared 10 Gigabit SFP+
Performance
Switching capacity: 960 Gbps , Throughput: 714 Mpps , 10 Gbps fibre latency (64-byte packets): 1.508 µs , 10 Gbps fibre latency (512-byte packets): 1.516 µs , 10 Gbps fibre latency (1024-byte packets): 1.516 µs , 10 Gbps fibre latency (1518-byte packets): 1.523 µs , 10 Gbps copper latency (64-byte packets): 2.409 µs , 10 Gbps copper latency (512-byte packets): 2.425 µs , 10 Gbps copper latency (1024-byte packets): 2.43 µs , 10 Gbps copper latency (1518-byte packets): 2.432 µs , 1 Gbps fibre latency (64-byte packets): 2.285 µs , 1 Gbps fibre latency (512-byte packets): 2.39 µs , 1 Gbps fibre latency (1024-byte packets): 2.426 µs , 1 Gbps fibre latency (1518-byte packets): 2.379 µs , 1 Gbps copper latency (64-byte packets): 2.702 µs , 1 Gbps copper latency (512-byte packets): 2.714 µs , 1 Gbps copper latency (1024-byte packets): 2.73 µs , 1 Gbps copper latency (1518-byte packets): 2.709 µs
Virtual interfaces (VLANs): 4093 , IGMP groups: 4000 , LAG groups: 128 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , IP router interfaces: 128 , OSPF IPv4 routes: 12288 , OSPF IPv6 routes: 4096
128K entries
Jumbo Frame Support
12KB
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
44 cm x 34.5 cm x 4.4 cm
6.55 kg
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
128K entries
Jumbo Frame Support
12KB
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
1: 800 MHz
RAM
1 GB
Flash Memory
256 MB
48 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Provided
250 watt
AC 120/230 V
237.2 watt
1 x mini-USB cable , 1 x console cable
MTBF
249,393 hours
CISPR 22 Class A, EN55024, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A, EN 55022 Class A
Europe, Americas
44 cm
34.5 cm
4.4 cm
6.55 kg
Limited warranty - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
CHJG NETGEAR 250W 100-240VAC Power Supply Unit In Stock £158.91
Ports: 48
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
