NETGEAR ProSAFE M4300-24X Switch 24 Ports Managed Rack-Mountable
VERSATILE STACKABLE SOLUTION
Quicklinx: CHJFWS00 Mfr#: XSM4324CS-100NES
Type: 10 Gigabit Ethernet
Ports: 24
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£3,258.10 ex VAT
£3,909.72 inc VAT
The NETGEAR M4300 Stackable Switch Series delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series, enabling spine and leaf line-rate stacking topologies. Non-stop forwarding (NSF) virtual chassis architectures provide advanced High Availability (HA) with hitless failover across the stack. Dual redundant, modular power supplies equipping full width models contribute to business continuity management. Layer 3 feature set includes static, dynamic and policy-based routing - as standard. Perfect for wireless access, unified communications and IP video, the NETGEAR M4300 Switch Series is also ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
  • Robust performance
    With a switching capacity of 480 Gbps and throughput of 357 Mpps, the NETGEAR M4300-24X ensures efficient handling of data across the network, minimizing latency and maximizing productivity.
  • Advanced security
    Features such as Access Control List (ACL) support, dynamic ARP protection, and IP source guard provide comprehensive security measures to protect against unauthorized access and threats.
  • Versatile connectivity
    Equipped with 24 10GBase-T ports and 4 shared 10 Gigabit SFP+ ports, this switch offers flexible connection options for a variety of network configurations and needs.
  • High reliability
    Designed for continuous operation with a mean time between failures (MTBF) of 247,437 hours, ensuring long-term reliability and peace of mind for your network infrastructure.
  • Efficient management
    Manageable via CLI, HTTPS, SNMP, SSH, and Telnet, the NETGEAR M4300-24X offers versatile management options to suit different administrative preferences and requirements.
NETGEAR M4300-24X - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10 Gigabit Ethernet + 4 x shared 10 Gigabit SFP+
Performance
Switching capacity: 480 Gbps , Throughput: 357 Mpps , 10 Gbps fibre latency (64-byte packets): 1.827 µs , 10 Gbps fibre latency (512-byte packets): 1.919 µs , 10 Gbps fibre latency (1024-byte packets): 1.971 µs , 10 Gbps fibre latency (1518-byte packets): 1.905 µs , 10 Gbps copper latency (64-byte packets): 2.728 µs , 10 Gbps copper latency (512-byte packets): 2.85 µs , 10 Gbps copper latency (1024-byte packets): 2.904 µs , 10 Gbps copper latency (1518-byte packets): 2.841 µs , 1 Gbps fibre latency (64-byte packets): 2.289 µs , 1 Gbps fibre latency (512-byte packets): 2.393 µs , 1 Gbps fibre latency (1024-byte packets): 2.423 µs , 1 Gbps fibre latency (1518-byte packets): 2.379 µs , 1 Gbps copper latency (64-byte packets): 2.707 µs , 1 Gbps copper latency (512-byte packets): 2.821 µs , 1 Gbps copper latency (1024-byte packets): 2.866 µs , 1 Gbps copper latency (1518-byte packets): 2.826 µs
Virtual interfaces (VLANs): 4093 , IGMP groups: 4000 , LAG groups: 128 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , IP router interfaces: 128 , OSPF IPv4 routes: 4096 , OSPF IPv6 routes: 256
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
21.2 cm x 34.5 cm x 4.4 cm
4.14 kg
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
1: 800 MHz
RAM
1 GB
Flash Memory
256 MB
24 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Provided
250 Watt
AC 120/230 V
125 Watt
1 x mini-USB cable , 1 x console cable
MTBF
247,437 hours
CISPR 22 Class A, EN55024, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A, EN 55022 Class A
Europe, Americas
21.2 cm
34.5 cm
4.4 cm
4.14 kg
Limited warranty - lifetime
50 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Ports: 24
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
