The NETGEAR M4300 Stackable Switch Series delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series, enabling spine and leaf line-rate stacking topologies. Non-stop forwarding (NSF) virtual chassis architectures provide advanced High Availability (HA) with hitless failover across the stack. Dual redundant, modular power supplies equipping full width models contribute to business continuity management. Layer 3 feature set includes static, dynamic and policy-based routing - as standard. Perfect for wireless access, unified communications and IP video, the NETGEAR M4300 Switch Series is also ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
Robust performance
With a switching capacity of 480 Gbps and throughput of 357 Mpps, the NETGEAR M4300-24X ensures efficient handling of data across the network, minimizing latency and maximizing productivity. -
Advanced security
Features such as Access Control List (ACL) support, dynamic ARP protection, and IP source guard provide comprehensive security measures to protect against unauthorized access and threats. -
Versatile connectivity
Equipped with 24 10GBase-T ports and 4 shared 10 Gigabit SFP+ ports, this switch offers flexible connection options for a variety of network configurations and needs. -
High reliability
Designed for continuous operation with a mean time between failures (MTBF) of 247,437 hours, ensuring long-term reliability and peace of mind for your network infrastructure. -
Efficient management
Manageable via CLI, HTTPS, SNMP, SSH, and Telnet, the NETGEAR M4300-24X offers versatile management options to suit different administrative preferences and requirements.
- NETGEAR M4300-24X - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10 Gigabit Ethernet + 4 x shared 10 Gigabit SFP+
- Performance
- Switching capacity: 480 Gbps , Throughput: 357 Mpps , 10 Gbps fibre latency (64-byte packets): 1.827 µs , 10 Gbps fibre latency (512-byte packets): 1.919 µs , 10 Gbps fibre latency (1024-byte packets): 1.971 µs , 10 Gbps fibre latency (1518-byte packets): 1.905 µs , 10 Gbps copper latency (64-byte packets): 2.728 µs , 10 Gbps copper latency (512-byte packets): 2.85 µs , 10 Gbps copper latency (1024-byte packets): 2.904 µs , 10 Gbps copper latency (1518-byte packets): 2.841 µs , 1 Gbps fibre latency (64-byte packets): 2.289 µs , 1 Gbps fibre latency (512-byte packets): 2.393 µs , 1 Gbps fibre latency (1024-byte packets): 2.423 µs , 1 Gbps fibre latency (1518-byte packets): 2.379 µs , 1 Gbps copper latency (64-byte packets): 2.707 µs , 1 Gbps copper latency (512-byte packets): 2.821 µs , 1 Gbps copper latency (1024-byte packets): 2.866 µs , 1 Gbps copper latency (1518-byte packets): 2.826 µs
- Capacity
- Virtual interfaces (VLANs): 4093 , IGMP groups: 4000 , LAG groups: 128 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , IP router interfaces: 128 , OSPF IPv4 routes: 4096 , OSPF IPv6 routes: 256
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI
- ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
- IEEE 802.3ad (LACP), IEEE 802.3az
- Power
- AC 120/230 V
- 21.2 cm x 34.5 cm x 4.4 cm
- 4.14 kg
- Localisation
- Europe, Americas
- NETGEAR lifetime warranty
- Enclosure Type
- Subtype
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Max Units In A Stack
- 8
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Processor
- 1: 800 MHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 24 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Provided
- 250 watt
- Voltage Required
- AC 120/230 V
- 125 watt
- Cables Included
- 1 x mini-USB cable , 1 x console cable
- MTBF
- 247,437 hours
- CISPR 22 Class A, EN55024, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A, EN 55022 Class A
- Localisation
- Europe, Americas
- 21.2 cm
- 34.5 cm
- 4.4 cm
- 4.14 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
NETGEAR 250W 100-240VAC Power Supply Unit | In Stock | £158.91 |
