The Prosafe Plus switch is an upgrade to unmanaged switch which can only Plug-N-Play, and is not configurable. Prosafe Plus switch gives user the flexibility to configure certain static layer 2 settings to better fit their needs. The GS116E is a 16-port Gigabit switch.
GS116E supports loop detection. When a loop is detected, the both LED on the affected port will blink at a constant speed with roughly 1 every second. Dos is a form of attack on computer network resources. The Auto Dos feature of GS116E would automatically block malicious packets such as source IP equals destination IP.
- NETGEAR Plus GS116Ev2 - switch - 16 ports - Managed
- Switch - 16 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Jumbo Frame Support
- Remote Management Protocol
- HTTP
- Flow control, auto-negotiation, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, Quality of Service (QoS), reset button, loop prevention
- 28.6 cm x 10.1 cm x 1.59 cm
- 0.84 kg
- Localisation
- United Kingdom
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- HTTP
- Status Indicators
- Port status, power
- 16 x 1000Base-T RJ-45
- Power Device
- External power adapter
- 10 Watt
- FCC Class A certified, C-Tick Class A, KC, VCCI Class A, CCC Class A
- Localisation
- United Kingdom
- 28.6 cm
- 10.1 cm
- 1.59 cm
- 0.84 kg
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £7.93 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.55 |
