NETGEAR ProSafe GS108T 8-Port Gigabit Smart Switch
LIFETIME WARRANTY
Quicklinx: 4N48WS00 Mfr#: GS108T-200UKS
Joining NETGEAR's family of Gigabit Smart Switches with web-based management, this 8-port Gigabit switch is high on value and capability. With 8 10/100/1000 Mbps ports and support for Jumbo frames, capable of powering 2000 Mbps of data throughput in full-duplex mode, it is ideal for small offices or extensions and connects high-speed servers or power users. Ideal for combining 10, 100, and 1000 Mbps devices it delivers automatic speed and full/half-duplex sensing plus Auto Uplink on every port. In addition, an intuitive web-browser interface offers the simple Smart Switch management, making it easy to configure ports and set up port trunks, VLANs and traffic prioritization or monitor switch performance. The GS108T is equipped with highly advanced features such as Access Control Lists (ACL), 802.1x port authentication, enhanced QoS, rate limiting and IGMP Snooping among others to provide a small and medium-sized business with a network that is geared for growth while providing scalability and reliability.
NETGEAR GS108T 8-Port Gigabit Smart Switch - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 2c, HTTP
Flow control, DHCP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, traffic shaping, port mirroring, store and forward, Broadcast Storm Control, firmware upgradable, SNTP support, wall mountable, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP)
AC 120/230 V (50 - 60 Hz)
23.5 cm x 10.1 cm x 2.6 cm
0.69 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
8K entries
Authentication Method
RADIUS
Status Indicators
Port transmission speed, power, link OK, link/activity
8 x 1000Base-T RJ-45
External power adapter
12 Watt
Mounting Kit
Included
MTBF
108,016 hours
C-Tick, EN 60950, IEC950, VCCI Class A ITE, EN55024, FCC Part 15 A
Europe
Software Included
Drivers & Utilities
23.5 cm
10.1 cm
2.6 cm
0.69 kg
Limited warranty - lifetime
50 °C
0 - 90%
4N48 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
4N48 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.56
