NetGear PROSAFE DUAL WAN GIGABIT FIREWALL ROUTER SSL IPSEC
Customer rating: 5.0* (Write a review)
Quicklinx: 4SPFWS00 Mfr#: FVS336G-100EUS
NETGEAR's ProSafe Dual WAN Gigabit Firewall with SSL & IPsec VPN offers the best of both worlds by offering two types of virtual private network (VPN) tunnels, Secure Sockets Layer (SSL) and IP security (IPsec), for optimal secure connection to your network. SSL VPN tunnels provide clientless remote access to your corporate data for individual access anywhere and anytime while IPsec VPN tunnels provide both secure site-to-site tunnels and legacy support for client-based remote access. Backed by a true firewall, this VPN router is a high-performance, SNMP-manageable, network solution that furnishes multidimensional security including denial-of-service (DoS) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts. Four Gigabit LAN ports keep your data moving at top speed while two Gigabit WAN ports provide load-balancing and failover protection to ensure maximum throughput and reliable connectivity to the Internet. With Network Address Translation (NAT) routing and classical routing, up to 253 users can access your broadband connection at the same time.
NETGEAR ProSafe FVS336G - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
Throughput: 60 Mbps , VPN throughput (3DES IPSec): 16 Mbps , VPN throughput (SSL): 10 Mbps
IPSec VPN tunnels: 25 , SSL VPN peers: 10 , Concurrent sessions: 10000 , Connection / user qty:
Network / Transport Protocol
TCP/IP, UDP/IP, NTP, ICMP/IP, IPSec, PPPoE, SMTP, FTP, DHCP, DNS, POP3
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS
Firewall protection, auto-sensing per device, dynamic IP address assignment, DHCP support, NAT support, VPN support, auto-negotiation, load balancing, auto-uplink (auto MDI/MDI-X), Syslog support, SPI, DoS attack prevention, content filtering, packet filtering, E-mail alert, VPN passthrough, URL filtering, IP address filtering, QoS, IPSec NAT-T, DHCP server
25.4 cm x 17.8 cm x 4 cm
1.7 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, RSA, MD5, ARCFOUR, IKE, DH, SHA-1, TLS 1.0, SSL 3.0, DSA, PKI, 128-bit AES, 256-bit AES
Authentication Method
X.509 certificates
1 x 300 MHz
RAM
64 MB SDRAM
Flash Memory
16 MB
Status Indicators
Port transmission speed, power, link OK, test mode, link/activity
WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
1 x network cable
Europe
Software Included
Drivers & Utilities, ProSafe VPN Client (1 user licence)
25.4 cm
17.8 cm
4 cm
1.7 kg
0 - 90%
Customer reviews
Write a review for the NetGear PROSAFE DUAL WAN GIGABIT FIREWALL ROUTER SSL IPSEC here!
Nice
Reviewed by Andy. Review Posted 14/08/2008
I only use this with a single WAN but it was easy to set up, keeps up with the traffic and has caused me no problems. I did update to the latest 3.xx firmware as soon as I got it so this probably helped.
A nice piece of kit.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very Good SMB Firewall Product
Reviewed by Anonymous Review Posted 27/10/2009
I bought this device about a year ago and have been using it since. Very easy to set-up if you are semi-technical. There are lots of guides and instructions on how to configure in various environments. Rather disappointed that the VPN client software supplied does not work with 64-bit systems, the NetGear support response to issue this was very poor. There is free-ware software that provides the same functionality.
  • Overall 4*
  • Ease of use 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
