Your ports, where you want them
Today's networks have increasing numbers of devices attached to them. As wired devices proliferate, it can be difficult to easily and neatly place networked ports where you want them.
NETGEAR ProSAFE Click Switches™ address this issue head on.
These innovative Gigabit Ethernet switches come with an industry-first, bracket mounting system for easy installation. With a flexible and unique 1-2-3-4 click arrangement, it's easier than ever to enable optimal placement and cable management in locations where other switches will not go.
Vertical/side mount, Vertical/rear mount, Horizontal/side mount and Horizontal/rear mount.
- Available in either 8- or 16-Gigabit port configurations
- Slim design with internal power supplies
- Sleek cable management system
- Prioritise and manage bandwidth usage with intuitive web browser as seen on the ProSAFE Plus series
Put an end to unsightly cables and switch placement challenges. Deliver a better way for customers to put their ports, where they want them. Available now, click here for your Click Switch from authorised NETGEAR channels.
- NETGEAR Click GSS116E - switch - 16 ports - Managed
- Switch - 16 ports - Managed
- Ports
- 16 x 10/100/1000
- Performance
- Bandwidth: 32 Gbps
- Capacity
- Virtual interfaces (VLANs): 128 , Layer 2 multicast groups: 128
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Remote Management Protocol
- TFTP
- Flow control, network monitoring, trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, vertical mounting, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), horizontal mounting, Jumbo Frames support, fanless, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, loop prevention, Multicast filtering function, tagged VLAN, 4MB packet buffer, metal housing, Type of Service (ToS), DiffServ Code Point (DSCP) support
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az
- 7 cm x 40.7 cm x 3.5 cm
- 1.3 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Ports
- 16 x 10/100/1000
- Performance
- Capacity
- 8K entries
- 9KB
- TFTP
- Status Indicators
- Port transmission speed, power, link/activity
- 16 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- 8.4 Watt
- Included Accessories
- Cable retaining straps, 1-2-3-4 mounting kit
- MTBF
- 721,479 hours
- VCCI, C-Tick, cUL, EN 60950, EN55022, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, CISPR 22, EN50082-1, CCC, FCC Part 15
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 7 cm
- 40.7 cm
- 3.5 cm
- 1.3 kg
- Limited warranty - lifetime , Limited warranty - power supply - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.18 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.05 |
