NetGear ProSafe AXM764 SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LRL LC Single Mode
Quicklinx: BYL2WS00 Mfr#: AXM764-10000S
19 in stock
£264.57 ex VAT
£317.48 inc VAT
10GBASE-SR is a port type for MMF (multimode fiber) and uses 850 nm lasers. For longer reach, another standard defined in IEEE 802.3ae is 10GBASE-LR. 10GBASE-LR is a port type for SMF (single mode fiber) and uses 1310 nm lasers. Traditionally SMF 10GBASE-LR SFP+ modules are way more expensive than MMF 10GBASE-LR SFP+ modules. MMF and SMF historical short range / long range paradigm may change in short term: since 2014, for new installations, especially indoor, SMF wiring is about half of MMF wiring. As a consequence, lots of new buildings and datacenters now standardize on SMF. But 10GBASE-LR SFP+ transceivers are too expensive for short-range connections. A new market for short distances over SMF has been created: the industry is standardizing on a new class of SMF 10G transmitters with typical 10GBASE-LR LITE SFP+ transceivers. While not a standard yet, 10GBASE-LR LITE has a specified reach of 2 km over standard 9µm single mode fiber. 10GBASE-LR LITE isn’t a replacement for 10GBASE-LR optics: it is just relevant alternative for "shorter" reach SMF applications.
NETGEAR ProSafe AXM764 - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LRL
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 GigE
Max Transfer Distance
2 km
1.455 cm x 5.65 cm x 1.185 cm
20 g
5-year warranty
NETGEAR M4300-28G-PoE+
Plug-in module
Wired
Cabling Type
10GBase-LRL
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
2 km
IEEE 802.3ae
1 x Ethernet 10GBase-LRL - LC single-mode x 2
MTBF
2,310,000 hours
RoHS, Laser Class 1, FDA, CDRH, IEC 60825, 21 CFR 1040.10, 21 CFR 1040.11
1.1 Watt
1.455 cm
5.65 cm
1.185 cm
20 g
Limited warranty - 5 years
-5 °C
85 °C
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
