The ProSAFE Auxiliary Power Supply APS135W provides a replaceable power supply for the GSM73xxSv2 series gigabit switches. You can make use of an RPS (Redundant Power Supply) while replacing the power supply. When an RPS is used, the power supply can be replaced without stopping the switch or requiring a reboot.
- NETGEAR MGD SW 135W - power supply - 135 Watt
- Power supply - plug-in module
- Power Capacity
- 135 Watt
- Designed For
- NETGEAR GSM7328S, GSM7328Sv2, GSM7352S, GSM7352Sv2
- Power Capacity
- 135 Watt
- RoHS
- Designed For
