The GS110TPv3 adds full 8 port PoE support for deployment of modern PoE devices. Cautious spender organizations can now deploy PoE devices connected to a cost effective switch, with a reasonable PoE power budget of 55W. Each port can provide up to 30 watts to power up connected devices. Fanless, the GS110TPv3 supports perfectly silent desktop operation or wall mounting.
Enhanced security
With support for RADIUS and TACACS+ authentication methods, alongside TLS 1.2 encryption, the NETGEAR Smart GS110TPv3 ensures secure network access and data transmission. -
Robust performance
Featuring a 20 Gbps switching fabric bandwidth and a forwarding performance of 14.8 Mpps, this switch is designed to handle demanding network environments efficiently. -
Comprehensive network management
Manageable via HTTP, HTTPS, SNMP, and more, the GS110TPv3 offers advanced control over your network, including features like Access Control List (ACL) support, Advanced QoS, and IGMP snooping for optimized performance. -
Power and connectivity
Equipped with 8 PoE+ ports and a total PoE budget of 55 W, along with two SFP slots for fiber connectivity, this switch supports a wide range of devices and deployment scenarios. -
Energy-efficient design
The fanless design not only ensures silent operation but also incorporates ENERGY STAR for reduced power consumption, making it an eco-friendly choice for any business.
- NETGEAR Smart GS110TPv3 - switch - 8 ports - smart
- Switch - 8 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE) + 2 x SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 55 W
- Performance
- Switching fabric bandwidth: 20 Gbps , Forwarding performance (64-byte packet size): 14.8 Mpps
- Capacity
- Packet buffer size: 512 KB , ACL entries (ingress): 100 , VLANs supported: 64 , IPv4 routes (static): 32
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 10KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3, static IPv4 routing, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPv6
- IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, MLD snooping, fanless, LACP, DHCP client, dual firmware images, loop prevention, tagged VLAN, cable test, LLDP-MED, protected ports, EEE, WRR, Advanced QoS, Unknown Storm Control, security slot (Kensington security lock compatible)
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- DC 54 V
- 23.6 cm x 10.1 cm x 2.7 cm
- 610 g
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 55 W
- Performance
- Capacity
- 8K entries
- 10KB
- Routing Protocol
- Encryption Algorithm
- TLS 1.2
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 500 MHz
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port status, PoE, link/activity/speed
- 8 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP
- Power Device
- External power adapter
- Voltage Required
- DC 54 V
- 69.5 watt
- Power Consumption Stand by
- 4.3 watt
- Included Accessories
- Wall mounting kit
- MTBF
- 1,200,041 hours
- Localisation
- Europe
- 23.6 cm
- 10.1 cm
- 2.7 cm
- 610 g
- Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - phone consulting - 90 days
- 0 °C
- 40 °C
- 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
